Re: How do you hook a Tach to MSD ignition?
[Re: Ramrod39]
#841232
10/28/10 11:16 PM
10/28/10 11:16 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Not if you want to keep that tach. There is a dedicated terminal on the side of the MSD box to drive the tach pulse. The coil pulse on an MSD is about 440volts and will fry a tach. And not all tachs will work with an MSD, especially older ones. There is usually a compatibility sheet in the manual.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Golden-Arm]
#841238
10/29/10 02:09 PM
10/29/10 02:09 PM
Posts: 9,123 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
you know, you can get a timing light with a built in tach, right? it will count the sparks, and display the number for you......
Will that work with an MSD? Aren't there multiple sparks sent down the plug wire?
