Re: Pilot bushing vs. pilot roller bearing
[Re: IMGTX]
#839553
10/26/10 08:16 PM
10/26/10 08:16 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Look at it like this. The only time the roller is rolling is when you shift. 99.9999% of the time the roller does nothing but it is one more part to go bad so I think the bushing is better.
Isn't the bronze bushing yet another part which can go bad, too?
For a street car with normal tolerances, I say it doesn't matter which you use, bearing or bushing, so take your pick.
[Re: fourgearsavoy]
#839554
10/26/10 09:42 PM
10/26/10 09:42 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I like the bronze one that presses into the converter register.There is a Mopar part number in the archives.
Would that bushing be 53009180AB? If it is, I'm leaning toward that one.
[Re: theclutcher]
#839556
10/27/10 11:38 AM
10/27/10 11:38 AM
Commando1
take the time and indicate the bellhousing to within .007 or better. Doing that with eliminate any concerns of wear with either component. Plus all the other benefits but thats another topic.
You know, if you think about it, if I do ALL things I'm supposed to do, Both would be 100% fine with me.
Good advice...
[Re: Stanton]
#839559
10/27/10 06:35 PM
10/27/10 06:35 PM
Posts: 4,954 WI
Dcuda69
WI
The factory used the bushing for years. I suspect the only reason for using the bearing was to save on labor costs of drilling the cranks as well as having specific cranks for 4-gear applications. My vote goes with the non-moving part - the bushing.
They used the bearings for years too......think Dakotas,etc. That's the bearing that's in my BB. With that said ....either will work fine,pick one that fits your app.(crank register,etc)and put it together. Mine's been together for many years with the bearing...no problems.
[Re: fourgearsavoy]
#839561
10/27/10 08:20 PM
10/27/10 08:20 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
either will work fine almost every car built for the last 15-20 years with a stick comes with a roller bearing on the pilot and it's not uncommon to see them go 100k plus.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
