carb size ?? #839194
10/25/10 11:18 PM
10/25/10 11:18 PM
ca, slo.
P
paulyvault Offline OP
P
ca, slo.
so i am running a 383 30 over with nothing special pretty stock. i have been looking at carbs and was thinking about a 650, the car is just a fun goood driver. anyone have any ideas ? thanks
Re: carb size ?? [Re: paulyvault] #839195
10/25/10 11:27 PM
10/25/10 11:27 PM
Az
Crizila Offline
Crizila  Offline
Az
750 Holley 3310, vacuum secondary and electric choke.
Fastest 300
Re: carb size ?? [Re: Crizila] #839196
10/25/10 11:32 PM
10/25/10 11:32 PM
ca, slo.
P
P
ca, slo.
yea i have a 750 dule feed and its just seeming like to much.
Re: carb size ?? [Re: paulyvault] #839197
10/25/10 11:49 PM
10/25/10 11:49 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
My 383 .03 over loved the 770 Street Avenger. The heads were ported and polished and it runs like no other 383. I had to increase the fuel line to 3/8" and have not had it back to the track since,
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: carb size ?? [Re: paulyvault] #839198
10/25/10 11:59 PM
10/25/10 11:59 PM
Huber Heights Ohio
greenpigs Offline
greenpigs  Offline
Huber Heights Ohio
For just a weekend ride I would think a 650 would be fine. Grab a Proform if you can swing it.
69 Charger RT
Re: carb size ?? [Re: dfsmopars] #839199
10/26/10 02:23 AM
10/26/10 02:23 AM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
383 and .030 over. 770 Street Avenger, vacumn secondarys, 3.55 rear, 3000 stall, TTI headers, mandrel 2-1/2 exhaust, 484 cam and I am VERY Happy with it.
Re: carb size ?? [Re: paulyvault] #839200
10/26/10 02:46 AM
10/26/10 02:46 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Sounds to me more like you should tune what you have. Pick yourself up a tuning kit from summit and have at it.
Re: carb size ?? [Re: paulyvault] #839201
10/26/10 07:47 AM
10/26/10 07:47 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""yea i have a 750 dule feed and its just seeming like to much""
Is it a vacuum secondary unit or a DP unit? Both come in dual feel inlets, so I was just curious.
Can you give us the part number?
You might have just what you need already.
Re: carb size ?? [Re: paulyvault] #839202
10/26/10 08:07 AM
10/26/10 08:07 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Since you have a magnum motor (I assume), the
625 Carter or 650 Holley is fine for what you wnat to do.
As Daytona sugguested fine tune it to how YOUR
DRIVING HABITS are. You never indicated any mods
to the engine, so leave well enough alone with the stock setup! With some carb/ignition tuning, you will be on your way!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: carb size ?? [Re: YO7_A66] #839203
10/26/10 08:13 AM
10/26/10 08:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Either will work. Just have to tune it. Nothing is going to work perfect out of the box. You need the right spring, power valve, jets and squirters and the Holley should work great.
Coming soon!!!!
Re: carb size ?? [Re: Crizila] #839204
10/26/10 01:02 PM
10/26/10 01:02 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
My setup is a 383 with XE262H Comp Cam, headers, RPM intake, 3310 Holley 750. I have it dialed in good. Works really well.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: carb size ?? [Re: Junky] #839205
10/26/10 02:05 PM
10/26/10 02:05 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Same carb here, needed to do some tuning. Now it's .
Re: carb size ?? [Re: paulyvault] #839206
10/26/10 03:28 PM
10/26/10 03:28 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
This was just covered lately...........
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Hopefully it's some help.
Re: carb size ?? [Re: Dean_Kuzluzski] #839207
10/26/10 03:43 PM
10/26/10 03:43 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
box stock universal 600 holley with electric choke will feed it fine and work great for a stock 383 driver.
Re: carb size ?? [Re: Dean_Kuzluzski] #839208
10/29/10 10:55 PM
10/29/10 10:55 PM
Desert Tracker
Desert Tracker
Good reference!! But we'll call this a -stirrer HELPING OUT!!
Re: carb size ?? [Re: superbyrd] #839209
10/29/10 11:01 PM
10/29/10 11:01 PM
Desert Tracker
Desert Tracker
GOOD choice, just make sure the jetting is correct
for the 383 (MOPAR!) and the choke/accelerator linkages and float/idle settings are all to spec.
Re: carb size ?? [Re: paulyvault] #839210
10/29/10 11:03 PM
10/29/10 11:03 PM
Desert Tracker
Desert Tracker
Jet it down.
Re: carb size ?? [Re: paulyvault] #839211
10/31/10 01:36 PM
10/31/10 01:36 PM
Aurora, CO
Manifold Offline
Manifold  Offline
Aurora, CO
X3 on the Holley Street Avenger 770cfm. I pulled a Carter Comp Plus AFB 625cfm off and popped the 770 on and the motor ran smoother, the carb adjusted very well, and the motor loves it.
I was concerned the 770cfm would be too much for my 383, but was pleasantly surprised.
Re: carb size ?? [Re: Manifold] #839212
10/31/10 03:53 PM
10/31/10 03:53 PM
Desert Tracker
Desert Tracker
The COMP Plus was jetted for performance for a smaller (270-330)engine-slightly big cam where the 770 is
set for STREET performance with a performance street cam in a small (350) to midsize (400) big block. A EDDY 650? AFB for STREET performance would have worked well too!!
Re: carb size ?? [Re: Manifold] #839213
11/02/10 11:08 AM
11/02/10 11:08 AM
Desert Tracker
Desert Tracker
If you have a good flowing exhaust setup and a decent intake, the bigger carbs will work, but there is a mileage penalty. You are getting away
from the cruiser mode. Might as well stick a hotter cam in it to take advantage of the better breathing characteristics!
