Re: carb size ??
[Re: paulyvault]
#839195
10/25/10 11:27 PM
10/25/10 11:27 PM
Posts: 7,506 Az
Crizila
Az
750 Holley 3310, vacuum secondary and electric choke.
Fastest 300
Re: carb size ??
[Re: paulyvault]
#839197
10/25/10 11:49 PM
10/25/10 11:49 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
My 383 .03 over loved the 770 Street Avenger. The heads were ported and polished and it runs like no other 383. I had to increase the fuel line to 3/8" and have not had it back to the track since,
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: carb size ??
[Re: paulyvault]
#839200
10/26/10 02:46 AM
10/26/10 02:46 AM
DaytonaTurbo
Manitoba, Canada
yea i have a 750 dule feed and its just seeming like to much.
Sounds to me more like you should tune what you have. Pick yourself up a tuning kit from summit and have at it.
Re: carb size ??
[Re: paulyvault]
#839201
10/26/10 07:47 AM
10/26/10 07:47 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
""yea i have a 750 dule feed and its just seeming like to much""
Is it a vacuum secondary unit or a DP unit? Both come in dual feel inlets, so I was just curious.
Can you give us the part number? You might have just what you need already.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: carb size ??
[Re: YO7_A66]
#839203
10/26/10 08:13 AM
10/26/10 08:13 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Either will work. Just have to tune it. Nothing is going to work perfect out of the box. You need the right spring, power valve, jets and squirters and the Holley should work great.
Re: carb size ??
[Re: Crizila]
#839204
10/26/10 01:02 PM
10/26/10 01:02 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
My setup is a 383 with XE262H Comp Cam, headers, RPM intake, 3310 Holley 750. I have it dialed in good. Works really well.
Re: carb size ??
[Re: Junky]
#839205
10/26/10 02:05 PM
10/26/10 02:05 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
Same carb here, needed to do some tuning. Now it's .
