Re: A body power steering auto column shift to floor
[Re: Pntastar69]
#838892
10/26/10 03:49 PM
10/26/10 03:49 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
Remove the bowls, cut the shifter tab and gear indicator tab off, fill them in, then repaint.
\ this is a quick and cheap way of doing it. Even if I scored a manual column I would sell it and do it this way. the finished product will look way nicer.
[Re: west]
#838893
10/26/10 05:53 PM
10/26/10 05:53 PM
Posts: 639 Wilmington, NC
donbarnes
Not THAT Don Barnes!!
Wilmington, NC
+1 here, not hard on the Mopars to cut off the mentioned pieces, fill, sand and repaint it to make it look like a floor shift column. A little time consuming, but quicker than looking for and changing out everything to a 4-speed column, and you can't tell the difference when it's done..
[Re: donbarnes]
#838894
10/27/10 07:01 AM
10/27/10 07:01 AM
Posts: 607 NY
old340dog
NY
I've been wanting to do something like this also. I've heard it is easy to switch the tops sections. But have never seen any details on doing it.I've been a little leary of tearing mine up and running into a problem. Same with cutting the column shift piece off. Can someone post some instructions and pics etc here to help some of us out? thanks,
old340dog
[Re: old340dog]
#838895
10/28/10 12:14 AM
10/28/10 12:14 AM
west
petaluma,ca. u.s.a.
Don't be intimidated. go for it. The part you are modifying is very cheap and easy to find.
