A body power steering auto column shift to floor #838887
10/25/10 07:06 PM
10/25/10 07:06 PM
New Brunswick
U
Unfair Advantage Offline OP
U
New Brunswick
Is there a slick means of switching an auto column shift {power} to floor getting rid of PRND display and shift arm /. Can the column cowling be switched to smooth type or is it more involved than this.?? Thanks
Re: A body power steering auto column shift to floor [Re: Unfair Advantage] #838888
10/25/10 10:17 PM
10/25/10 10:17 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
the best way is to find a 4 speed column.
Re: A body power steering auto column shift to floor [Re: Unfair Advantage] #838889
10/26/10 01:12 AM
10/26/10 01:12 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Find a 4 speed column? Sure. They are everywhere, and cheap too. I see them for $5 at every swap meet.
NOT.
Heres a better idea. Look in your local wrecking yards for 72-80 Dodge trucks with 4 speeds. The steering column parts are very similar. I have converted several column shift steering columns this way. They will not have the key lock lever like all the 71 and later cars did, but that wasn't an issue for me.
Re: A body power steering auto column shift to floor [Re: Unfair Advantage] #838890
10/26/10 09:51 AM
10/26/10 09:51 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Remove the bowls, cut the shifter tab and gear indicator tab off, fill them in, then repaint.
Re: A body power steering auto column shift to floor [Re: Kern Dog] #838891
10/26/10 11:38 AM
10/26/10 11:38 AM
Poplar Bluff, Missouri
partfiler69 Offline
Still Wondering
Happy Birthday partfiler69  Offline
Still Wondering
NOT.
I don't know about 72-80 but my 82 truck did have a key release button, so if you find an 82-up column, it should have what you need. And they are easy to take apart. I have done several this way. Good luck.
Back from hiatus
Re: A body power steering auto column shift to floor [Re: Pntastar69] #838892
10/26/10 03:49 PM
10/26/10 03:49 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
this is a quick and cheap way of doing it.
Even if I scored a manual column I would sell it and do it this way.
the finished product will look way nicer.
Re: A body power steering auto column shift to floor [Re: west] #838893
10/26/10 05:53 PM
10/26/10 05:53 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
+1 here, not hard on the Mopars to cut off the mentioned pieces, fill, sand and repaint it to make it look like a floor shift column. A little time consuming, but quicker than looking for and changing out everything to a 4-speed column, and you can't tell the difference when it's done..
Re: A body power steering auto column shift to floor [Re: donbarnes] #838894
10/27/10 07:01 AM
10/27/10 07:01 AM
NY
old340dog Offline
old340dog  Offline
NY
I've been wanting to do something like this also. I've heard it is easy to switch the tops sections. But have never seen any details on doing it.I've been a little leary of tearing mine up and running into a problem.
Same with cutting the column shift piece off.
Can someone post some instructions and pics etc here to help some of us out?
thanks,
old340dog
Re: A body power steering auto column shift to floor [Re: old340dog] #838895
10/28/10 12:14 AM
10/28/10 12:14 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
thanks,
Don't be intimidated. go for it.
The part you are modifying is very cheap and easy to find.
