Q-Jet with RPM & adapter? #838646
10/25/10 03:22 PM
10/25/10 03:22 PM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Just wondering if this will work decent or not, are any of you running a Q-Jet on an RPM with the adapter? I'm looking for better mileage over my 650dp, Its on a 360 magnum with the Crosswind RPM, i have a 1705xxxx QJ in good condition & an adapter, i'm not to concerned about the linkage because i'm running a cheetah FMVB, so no kickdown, If anyone is running this set-up on there SB, How well do it do?
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Q-Jet with RPM & adapter? [Re: joedust451] #838647
10/25/10 04:44 PM
10/25/10 04:44 PM
Central NC
gch Offline
gch  Offline
Central NC
May not be relevant but years ago on 440 magnum I put a Tquad on my stock iron intake with an adapter and was not happy.Not having the secondary opening of the intake as large as the carb opening seemed to kill it.It did'nt run any better than the smaller holley on the iron intake.
IMO you need a spreadbore intake to get the benefit.
Re: Q-Jet with RPM & adapter? [Re: gch] #838648
10/25/10 04:59 PM
10/25/10 04:59 PM
scratchnfotraction Offline
it will work ok,just may not be the best combo
Re: Q-Jet with RPM & adapter? [Re: joedust451] #838649
10/25/10 05:32 PM
10/25/10 05:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Not sure why your mpg's would improve. I'd just tstick with what you have. Especially if it's on and tuned. If you are that concerned about mpg maybe lean it out some and set your timing back a few.
Coming soon!!!!
Re: Q-Jet with RPM & adapter? [Re: Mr.Yuck] #838650
10/25/10 05:41 PM
10/25/10 05:41 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
I guess i could lean it out some more, i'm back too the stock jetting (67/73)
My only option would be the M1 dual plane for the magnum, i think its spreadbore exceptable.
Re: Q-Jet with RPM & adapter? [Re: joedust451] #838651
10/25/10 05:45 PM
10/25/10 05:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
There's always the LD340 intake, can be modded to accept a thermoquad. Also, hotroddave was reporting good results with taking an adapter and porting it and the intake together to smooth out the transition.
Re: Q-Jet with RPM & adapter? [Re: DaytonaTurbo] #838652
10/25/10 06:04 PM
10/25/10 06:04 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
I have RHS magnum heads, & NO WAY am i re-drilling them for the LA intake.
Re: Q-Jet with RPM & adapter? [Re: joedust451] #838653
10/25/10 06:10 PM
10/25/10 06:10 PM
Manitoba, Canada
Manitoba, Canada
Drill the LA intake then. It's been done.
Re: Q-Jet with RPM & adapter? [Re: Mr.Yuck] #838654
10/25/10 06:12 PM
10/25/10 06:12 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Because a spreadbore carb has smaller primaries than a square bore.
Re: Q-Jet with RPM & adapter? [Re: DaytonaTurbo] #838655
10/25/10 06:18 PM
10/25/10 06:18 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
How hard is it too do? Doesn't look like theres enough meat in those areas for the straight down bolts. Does anyone have a pic??
Re: Q-Jet with RPM & adapter? [Re: joedust451] #838656
10/25/10 06:55 PM
10/25/10 06:55 PM
Manitoba, Canada
Manitoba, Canada
Not sure how hard it is, but I thought someone sold some wedge-shaped adapters kinda like a very thick washer so that when you tork your la intake down on magnum heads it keeps the bolts at a 90* angle to their mounting surface.
