8 3/4 axel questions #83596
07/03/08 05:39 PM
07/03/08 05:39 PM
Dexter, Michigan
copper67440 Offline OP
mopar addict
mopar addict
Dexter, Michigan
Which side does the adjustable axel belong on, I beleive it's the right. ?? Am I right? And why would it matter?
Re: 8 3/4 axel questions [Re: copper67440] #83597
07/03/08 06:00 PM
07/03/08 06:00 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
You are correct, passenger side.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 8 3/4 axel questions [Re: Prodart440] #83598
07/03/08 06:01 PM
07/03/08 06:01 PM
scratchnfotraction Offline
green bearings dont matter
Re: 8 3/4 axel questions [Re: copper67440] #83599
07/03/08 06:12 PM
07/03/08 06:12 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Right is the side the factory chose and is in manuals for uniformity sake. It doesn't matter which side you choose to put it on or if you have to under circumstances put in a used axle with good bearings and it has the adjuster use it on the other side too, using an adjuster on both sides. just set one side and and adjust the preload from the other.
Re: 8 3/4 axel questions [Re: MoparforLife] #83600
07/03/08 06:39 PM
07/03/08 06:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
True as long as the axles don't need LH threads on one side.
Re: 8 3/4 axel questions [Re: John_Kunkel] #83601
07/03/08 06:43 PM
07/03/08 06:43 PM
Dexter, Michigan
mopar addict
mopar addict
Dexter, Michigan
Thank you guys, I thought that was the way. Green brngs are currently out of my budget. Getting layed off for July shutdown this year, with three more weeks in August and Sept. ( Ford )
Re: 8 3/4 axel questions [Re: copper67440] #83602
07/03/08 06:59 PM
07/03/08 06:59 PM
Upper Midwest
Upper Midwest
Clean, inspect, and repack what you have if they are good. They are a superior bearing to the green bearing anyway and the couple of minutes more it takes to install them and as often as it is done (maybe once in a lifetime) just doesn't make sense.
Re: 8 3/4 axel questions [Re: MoparforLife] #83603
07/04/08 10:39 AM
07/04/08 10:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
