Re: 8 3/4 axel questions
[Re: copper67440]
#83597
07/03/08 06:00 PM
07/03/08 06:00 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
You are correct, passenger side.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: copper67440]
#83599
07/03/08 06:12 PM
07/03/08 06:12 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Which side does the adjustable axel belong on, I beleive it's the right. ?? Am I right? And why would it matter?
Right is the side the factory chose and is in manuals for uniformity sake. It doesn't matter which side you choose to put it on or if you have to under circumstances put in a used axle with good bearings and it has the adjuster use it on the other side too, using an adjuster on both sides. just set one side and and adjust the preload from the other.
[Re: copper67440]
#83602
07/03/08 06:59 PM
07/03/08 06:59 PM
MoparforLife
Upper Midwest
Thank you guys, I thought that was the way. Green brngs are currently out of my budget. Getting layed off for July shutdown this year, with three more weeks in August and Sept. ( Ford )
Clean, inspect, and repack what you have if they are good. They are a superior bearing to the green bearing anyway and the couple of minutes more it takes to install them and as often as it is done (maybe once in a lifetime) just doesn't make sense.
[Re: MoparforLife]
#83603
07/04/08 10:39 AM
07/04/08 10:39 AM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
