FUEL CELL #835602
10/21/10 04:41 PM
10/21/10 04:41 PM
Highland beach Fl
P
poisondart2 Offline OP
P
Highland beach Fl
Where does one find a fuel cell that is 10 gallons or bigger and has a - 12 outlet ? I acnt find one and I guess the other option is to drill a bigger hole ?
Re: FUEL CELL [Re: poisondart2] #835603
10/21/10 05:15 PM
10/21/10 05:15 PM
Guitar Jones Offline
Why not just get a -12 bulkhead and drill the hole?
See you can't buy anything either without having to modify it can ya?
Re: FUEL CELL [Re: Guitar Jones] #835604
10/21/10 05:20 PM
10/21/10 05:20 PM
Highland beach Fl
P
P
Highland beach Fl
Yeah Iam just plain lazy and figure that someone has a better plan than I do and what the heck to do with the other -8 guess it will look stumpy.
Re: FUEL CELL [Re: poisondart2] #835605
10/21/10 05:27 PM
10/21/10 05:27 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Do like I did...linked both -8's together....then went -10 from there forward. 2 hoses of equal size fill up a bucket faster than a single hose.
Re: FUEL CELL [Re: Chassisman] #835606
10/21/10 05:29 PM
10/21/10 05:29 PM
I was going to suggest that but he said he was lazy, making two hoses would be twice the effort of making one hose.
Re: FUEL CELL [Re: Chassisman] #835607
10/21/10 05:30 PM
10/21/10 05:30 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
that worked for me as well.
Re: FUEL CELL [Re: Guitar Jones] #835608
10/21/10 05:49 PM
10/21/10 05:49 PM
Highland beach Fl
P
P
Highland beach Fl
I have two -8's now and guess I could run them to a Y and then -12 out of the Y but doesnt that seem like alot of lines to get to one -12 ? Iam going from two pumps to only having one bigger pump. Has to be a better way or not?
Re: FUEL CELL [Re: poisondart2] #835609
10/21/10 07:16 PM
10/21/10 07:16 PM
Delray beach, Florida
P
Performance Only Offline
P
it's not only easier, but it's also less expensive to just buy the -12 bulkhead fitting and make the hole in the tank big enough to accept it.
if you want, bring it by the shop and we'll do it for you.
machine shop owner and engine builder
Re: FUEL CELL [Re: poisondart2] #835610
10/21/10 08:25 PM
10/21/10 08:25 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
mine are -10's
Re: FUEL CELL [Re: smokinwoody] #835611
10/21/10 08:48 PM
10/21/10 08:48 PM
Truckville, the capital of NY
85_Ram_4speed Offline
I took a -12 fitting and TIG'd it to the cell where the -8 resided formerly. Then i just capped the other -8 fitting on the cell. Seemed easy enough to me to do
Outcast Dodge guy.
