Re: remove paint from door VIN label
[Re: NANKET]
#830440
10/16/10 09:55 PM
10/16/10 09:55 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
If they were incompetent enough to paint over it, then they probably did'nt hit anything with sandpaper. So, the paint should be barely sticking. You might be able to cut the paint on the edge of the sticker with a razor blade and flake it off......carefully! Good luck!
Mo' Farts
Moderated by "tbagger".
