remove paint from door VIN label #830436
10/15/10 12:49 PM
10/15/10 12:49 PM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
I have a 1970 Plymouth, someone painted over the VIN label. I'm 99% certain its the original door, the underside has the right color paint on it, glass dated all the same. What will clean the paint off without destroying the sticker? anybody have a junk parts door they can try different solvents on?
Re: remove paint from door VIN label [Re: NANKET] #830437
10/15/10 05:19 PM
10/15/10 05:19 PM
PA
70Duster Offline
70Duster  Offline
PA
Don't use a solvent. There's a high probability it will destroy the sticker. Use 000 steel wool. This will work. I know this from personal experience.
Re: remove paint from door VIN label [Re: 70Duster] #830438
10/16/10 02:51 AM
10/16/10 02:51 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I used some type of solvent on mine - most likely laquer thinner or paint thinner, but I can't remember. It left the sticker intact, but it removed the VIN and date off the sticker, so it's basically a blank sticker now. The rest of the writing on the sticker is there, and the sticker looks good (not melted or streaked from the solvent), but the "important" things - the VIN and date, are gone. I've been thinking about recreating the VIN and date on the sticker, but that's pretty low on a long list right now.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: remove paint from door VIN label [Re: 70Duster] #830439
10/16/10 04:03 AM
10/16/10 04:03 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Don't know if its worth 49 bucks, but these guys sell them.... ECS Automotive
Re: remove paint from door VIN label [Re: NANKET] #830440
10/16/10 09:55 PM
10/16/10 09:55 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
If they were incompetent enough to paint over it, then they probably did'nt hit anything with sandpaper. So, the paint should be barely sticking. You might be able to cut the paint on the edge of the sticker with a razor blade and flake it off......carefully!
Good luck!
Mo' Farts
Moderated by "tbagger".
Re: remove paint from door VIN label [Re: Grizzly] #830441
10/16/10 10:02 PM
10/16/10 10:02 PM
Niagara, Ontario Canada
mrpatel Offline
mrpatel  Offline
If thats the case, you might be surprised by applying some masking tape and pulling it off on a 90 degree angle fairly quickly, or you could try scratching at it with you finger nail and compressed air. As noted above, try cutting around the outline.
Re: remove paint from door VIN label [Re: mrpatel] #830442
10/17/10 02:06 AM
10/17/10 02:06 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i took mine off with wash and wipe. crappy rattle can paint though.
