Page 3 of 4 1 2 3 4
Re: Hemi Oil Pump [Re: Keith Black®] #829828
11/05/10 06:34 PM
11/05/10 06:34 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
]Is the standard hemi pump up to the job of supply very high output street engine...?
yes
Re: Hemi Oil Pump [Re: HPMike] #829829
11/05/10 06:45 PM
11/05/10 06:45 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
Mike would you run it on your 1,500hp engine?
Can i fit another cover for remote filter ?
Darren Beale
Keith Black Racing Engines®
Re: Hemi Oil Pump [Re: Keith Black®] #829830
11/05/10 11:14 PM
11/05/10 11:14 PM
QLD Australia
QLD Australia
Does anyone have a pic of an Indy pump & cover?
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829831
11/06/10 06:21 PM
11/06/10 06:21 PM
QLD Australia
QLD Australia
Andy I may have to get you to machine me a cover up..?
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829832
11/06/10 09:50 PM
11/06/10 09:50 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
.. AND .... ta da.. the pump cover doesn't fit!
Does anyone make an oil pump cover:
1. external pick up, and
2. remote filer
that will clear the engine mount.? Help please
It will clear....you will have to grind about a 1/4" off the cover and if your using the rear port the motor mount bracket(webbing) will need to be almost completely removed. The isolator stud and nut might have to be shaved a bit too..
Re: Hemi Oil Pump [Re: 52savoy] #829833
11/07/10 12:26 AM
11/07/10 12:26 AM
QLD Australia
QLD Australia
Fred,
Have you got any pictures of a modified housing ? ...mount?
where on the housing would I shave 1/4 in?
would really appreciate anything, stuck with this problem at the moment!
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829834
11/07/10 12:42 AM
11/07/10 12:42 AM
Mt. Eden Ky.
Hemi Allstate Online content
Hemi Allstate  Online Content
Mt. Eden Ky.
There might be some help in this link.
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=4759108&an=0&page=11
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Hemi Oil Pump [Re: Hemi Allstate] #829835
11/07/10 01:41 AM
11/07/10 01:41 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
that's good link....
I no longer have the modified pump cover and mount so I can't post any pics but Hemi Allstate's
post should give you an idea..
let me change that..I do have the mount/isolator. I'll post a picture Sunday.
notice the bracket corner cut off. I also cut the rubber isolator off below the bracket. The gusset was removed but I welded a partial back in after I quit using the Milodon pump...also notice the thin isolator nut.
Re: Hemi Oil Pump [Re: 52savoy] #829836
11/07/10 02:44 PM
11/07/10 02:44 PM
Linden, MI
scottsgretch Offline
Linden, MI
I have the same problem with the milodon pump cover interferring with the motor mount on my aluminum hemi world block. About a 1/2-inch off. Already had the pump cover machined down on the rear by Tim Banning at FHO Hemi's in Ontario when he built me the motor for me. Thought that would take care of the problem but guess not!
I don't know if the cover can be machined any further without hurting it. I can replace the rear plug with a flush plug which would help but not take care of it oompletely. Was also told i could use a factory hemi pump cover to take care of the problem but don't know if that would do it or not. I can't complete installing my motor until i get this figures out. BAH!!!!
I'm trying to research this as best i can so I can find a soluton too.
I've tried to attach PICS but they must be too big.
Scott
Re: Hemi Oil Pump [Re: scottsgretch] #829837
11/07/10 04:57 PM
11/07/10 04:57 PM
QLD Australia
QLD Australia
Scott
Scott, I have the same set up as you. On first inspection it looked near impossible to get the Milodon cover to fit the pump, not surprised machining 1/2in is not enough. I'll take another look over the next day or so but need another cover (maybe an Indy cover?? need a pic).
Hopefully Fred as a solution, let's wait and see his pictures.. (thanks in advance Fred)
Darren Beale
Re: Hemi Oil Pump [Re: AndyF] #829838
11/07/10 11:57 PM
11/07/10 11:57 PM
QLD Australia
QLD Australia
That cover is one that I custom designed for my car. It wouldn't work for his application because I think he wants an external inlet on the cover.
Andy I don't need any inlet on the cover. I only the 2x lines for an remote filter (feed + return)... do you reckon your cover would work.. or could we modify it more easily to work?
Darren Beale
Re: Hemi Oil Pump [Re: 52savoy] #829839
11/08/10 12:02 AM
11/08/10 12:02 AM
QLD Australia
QLD Australia
......bracket. The gusset was removed but I welded a partial back in after I quit using the Milodon pump...also notice the thin isolator nut.
Fred, why did you quit using the Milodon pump?
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829840
11/08/10 12:03 AM
11/08/10 12:03 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Why not use a stock pump with a stock cover and a aftermarket spin on adapter for a remote filter lines.I have pick up a few from our local NAPA store for aprox $20.I probably have a few lying around the shop.
Re: Hemi Oil Pump [Re: B G Racing] #829841
11/08/10 12:14 AM
11/08/10 12:14 AM
QLD Australia
QLD Australia
Bob... I bought the Milodon pump assuming it would be a high quality piece, and as an insurance policy on the engine to some degree.
I may be a bit misguided but I still have a niggling feeling about using a stock pump on a high dollar motor... are the stock pumps really that good?
If so then it may be worth a go.???
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829842
11/08/10 12:34 AM
11/08/10 12:34 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Not a cheap option but the best wet sump available is the Titan pump. Can be set up for single inlet or dual inlet. Plumbed for a remote filter. Not sure the stock engine mounts would fly. Put an engine plate in and be done with it, good spot to mount the filter
Titan pumps
Re: Hemi Oil Pump [Re: Bigcube] #829843
11/08/10 12:46 AM
11/08/10 12:46 AM
QLD Australia
QLD Australia
Without a doubt the Titan looks like the best. I have to stick with the engine mounts so the Titan is out.
I am limited to pumps that fit with engine mounts, & that support remote filter.
Ideally, I wanted to use the Milodon pump ... this however seems to be looking less and less likely.
I will try to get a pump cover made that will work.
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829844
11/08/10 01:42 AM
11/08/10 01:42 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I retired the car and restored it.
I forgot to mention....The pictured isolator is new and isn't the one I cut the corner off for clearance.
Re: Hemi Oil Pump [Re: Keith Black®] #829845
11/08/10 05:08 AM
11/08/10 05:08 AM
Australia
Teamx Offline
Teamx  Offline
Australia
Darren, Can you use internal pickup with a deep pan, should be fine for a streeter although my block was tight with a 4.25 stroke!
Re: Hemi Oil Pump [Re: Teamx] #829846
11/08/10 05:11 AM
11/08/10 05:11 AM
Australia
Teamx Offline
Teamx  Offline
Australia
another!
Re: Hemi Oil Pump [Re: Teamx] #829847
11/08/10 06:43 AM
11/08/10 06:43 AM
QLD Australia
QLD Australia
thanks Tim, but the pickup is not the problem... its the depth/height of the pump including cover. If I had a cover that was shallow I may be able to get around it.
I think I will have to get a cover made.
Not sure what to do now
Darren Beale
Page 3 of 4 1 2 3 4
