Re: Hemi Oil Pump
[Re: Keith Black®]
#829828
11/05/10 06:34 PM
11/05/10 06:34 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
]Is the standard hemi pump up to the job of supply very high output street engine...?
yes
Re: Hemi Oil Pump
[Re: HPMike]
#829829
11/05/10 06:45 PM
11/05/10 06:45 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
Mike would you run it on your 1,500hp engine? Can i fit another cover for remote filter ?
-------------------------------- Darren Beale Keith Black Racing Engines®
Re: Hemi Oil Pump
[Re: Keith Black®]
#829830
11/05/10 11:14 PM
11/05/10 11:14 PM
Keith Black®
QLD Australia
Does anyone have a pic of an Indy pump & cover?
Re: Hemi Oil Pump
[Re: Keith Black®]
#829831
11/06/10 06:21 PM
11/06/10 06:21 PM
Keith Black®
QLD Australia
Andy I may have to get you to machine me a cover up..?
Re: Hemi Oil Pump
[Re: Keith Black®]
#829832
11/06/10 09:50 PM
11/06/10 09:50 PM
Posts: 4,254 State of Fascism
52savoy
State of Fascism
.. AND .... ta da.. the pump cover doesn't fit!
Does anyone make an oil pump cover:
1. external pick up, and 2. remote filer
that will clear the engine mount.? Help please
It will clear....you will have to grind about a 1/4" off the cover and if your using the rear port the motor mount bracket(webbing) will need to be almost completely removed. The isolator stud and nut might have to be shaved a bit too..
Re: Hemi Oil Pump
[Re: 52savoy]
#829833
11/07/10 12:26 AM
11/07/10 12:26 AM
Keith Black®
QLD Australia
Fred, Have you got any pictures of a modified housing ? ...mount? where on the housing would I shave 1/4 in?
would really appreciate anything, stuck with this problem at the moment!
Re: Hemi Oil Pump
[Re: Hemi Allstate]
#829835
11/07/10 01:41 AM
11/07/10 01:41 AM
52savoy
State of Fascism
that's good link.... I no longer have the modified pump cover and mount so I can't post any pics but Hemi Allstate's post should give you an idea.. let me change that..I do have the mount/isolator. I'll post a picture Sunday. notice the bracket corner cut off. I also cut the rubber isolator off below the bracket. The gusset was removed but I welded a partial back in after I quit using the Milodon pump...also notice the thin isolator nut.
Re: Hemi Oil Pump
[Re: Bigcube]
#829843
11/08/10 12:46 AM
11/08/10 12:46 AM
Keith Black®
QLD Australia
Without a doubt the Titan looks like the best. I have to stick with the engine mounts so the Titan is out.
I am limited to pumps that fit with engine mounts, & that support remote filter. Ideally, I wanted to use the Milodon pump ... this however seems to be looking less and less likely. I will try to get a pump cover made that will work.
Re: Hemi Oil Pump
[Re: Keith Black®]
#829844
11/08/10 01:42 AM
11/08/10 01:42 AM
52savoy
State of Fascism
......bracket. The gusset was removed but I welded a partial back in after I quit using the Milodon pump...also notice the thin isolator nut.
Fred, why did you quit using the Milodon pump?
I retired the car and restored it.
I forgot to mention....The pictured isolator is new and isn't the one I cut the corner off for clearance.
Re: Hemi Oil Pump
[Re: Teamx]
#829847
11/08/10 06:43 AM
11/08/10 06:43 AM
Keith Black®
QLD Australia
thanks Tim, but the pickup is not the problem... its the depth/height of the pump including cover. If I had a cover that was shallow I may be able to get around it. I think I will have to get a cover made. Not sure what to do now
