BESTest spray-bomb engine enamel ..?? #827056
10/11/10 12:27 AM
10/11/10 12:27 AM
Florida STAYcation
dOoC Offline OP
The village idiot's idiot
dOoC  Offline OP
Florida STAYcation
.... USED to use TRW brand ...I bought a couple of cases some years ago ....LOVED IT .. but I don't have any more.
WHAT do you use ?
Re: BESTest spray-bomb engine enamel ..?? [Re: dOoC] #827057
10/11/10 12:39 AM
10/11/10 12:39 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
I don't know if it's the BESTest, but I use Plastikote and had good results with it.
Re: BESTest spray-bomb engine enamel ..?? [Re: 440newport] #827058
10/11/10 12:44 AM
10/11/10 12:44 AM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
COME to think about it ..... I believe that PK made that for TRW.
Doesn't it cover and dry almost like a powder-coat?
Re: BESTest spray-bomb engine enamel ..?? [Re: dOoC] #827059
10/11/10 12:54 AM
10/11/10 12:54 AM
Florida, USA.
john e Offline
john e  Offline
Florida, USA.
I've had good luck with the Duplicolor brand. It goes on really thin and takes multiple coats, but once it cures it's very tough.
Street racing is a mystery to most people, but I've got it figured out. If it blows up with a single 4, go dual quads. If that goes, inject it. And fix it fast.
Re: BESTest spray-bomb engine enamel ..?? [Re: 440newport] #827060
10/11/10 12:58 AM
10/11/10 12:58 AM
Under My Car
Mopar_Country Offline
Under My Car
Re: BESTest spray-bomb engine enamel ..?? [Re: dOoC] #827061
10/11/10 01:02 AM
10/11/10 01:02 AM
440newport Offline
440newport  Offline
Yes, it covers really well with just 1 or 2 coats and is pretty durable I find.
Re: BESTest spray-bomb engine enamel ..?? [Re: 440newport] #827062
10/11/10 01:14 AM
10/11/10 01:14 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
My best results have always come from going to a paint shop that has the ability to put paint into spray cans.
Buy a quart of Centari or any other single stage of your choice, have 3 or 4 spray cans made up from that and you'll still have some left for touch-ups with those little foam brushes for later from whats left in the quart
Re: BESTest spray-bomb engine enamel ..?? [Re: idrivevintage] #827063
10/11/10 09:22 AM
10/11/10 09:22 AM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I have had great luck with Dupli Color, and it seems to hold up very well.
Re: BESTest spray-bomb engine enamel ..?? [Re: 4BBodies] #827064
10/11/10 04:51 PM
10/11/10 04:51 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
THX for the suggestions ....
BTW ...does anyone know what brands Napa, AZ and Advance handle ? ...and do they have the big cans?
Re: BESTest spray-bomb engine enamel ..?? [Re: dOoC] #827065
10/11/10 05:04 PM
10/11/10 05:04 PM
scratchnfotraction Offline
duplicolor this go round
plasticoat last go round
no complants on either
I used more than needed,about 4 full cans for a small block
2 cans on let flash dry for a couple hrs,hit it with other 2 cans
nice and thick and tuff when cured by the heat
Re: BESTest spray-bomb engine enamel ..?? [Re: dOoC] #827066
10/11/10 06:29 PM
10/11/10 06:29 PM
& when you have it as clean as you can then drown it w 2 buck fifty cans of ether starting fluid. On a hot day it flashes off quickly & takes off lint from your cleaning rag & last traces of oils. Nothing better for a final cleaning & as you know w painting it's (mostly) all in the prep
Re: BESTest spray-bomb engine enamel ..?? [Re: scratchnfotraction] #827067
10/11/10 07:10 PM
10/11/10 07:10 PM
Plasti-Kote # 226 Chrysler Orange.
Available at Car-Quest. (they usually have to order it!)
Covers great and lasted really well on my last street driven 440!
Here it is on the new one:
Re: BESTest spray-bomb engine enamel ..?? #827068
10/11/10 07:12 PM
10/11/10 07:12 PM
Better one of the paint un-obstructed by the decal:
Valve cover was wirewheeled with a cup on an angle grinder, pits were filled, some wire tabs removed and it was wiped with wax and grease remover before being painted.
Re: BESTest spray-bomb engine enamel ..?? #827069
10/11/10 10:02 PM
10/11/10 10:02 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
DON'T use VHT. Looks great, until your carb spills a little gas on it, then it peels up like crazy. Who would make a paint that doesn't stand up to gasoline, then call it an "engine paint"?.... I guess VHT would!
DAMHIK....
Re: BESTest spray-bomb engine enamel ..?? [Re: StealthWedge67] #827070
10/11/10 10:07 PM
10/11/10 10:07 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
PPG urethane car paint sprayed with a cheapo PreVal sprayer.
Re: BESTest spray-bomb engine enamel ..?? [Re: dOoC] #827071
10/12/10 12:03 AM
10/12/10 12:03 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
TRW worked fine for me...or was it VHT?? crap, I don't remember...it was THREE letters! VHT I suppose.
Re: BESTest spray-bomb engine enamel ..?? [Re: cornucopia] #827072
10/12/10 10:10 AM
10/12/10 10:10 AM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I agree with RapidRobert on degreasing it, he uses starting fluid, I use laquer thinner. Will kill just about any leftover greases/residues. I tried to rush one once, then had to do it over in 6 months........the paint lifted in several areas. I am sure it was because I skipped that step........it has been fine since I re-did it RIGHT..........here is my Dupli Color 340.
Re: BESTest spray-bomb engine enamel ..?? [Re: 4BBodies] #827073
10/12/10 10:12 AM
10/12/10 10:12 AM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Oh, I also use Dupli Color aluminum primer for water pumps/intake manifolds. It is green. Covers like crap, but seems to hold up well on an engine.
