Re: BESTest spray-bomb engine enamel ..??
[Re: dOoC]
#827059
10/11/10 12:54 AM
10/11/10 12:54 AM
Posts: 105 Florida, USA.
john e
Florida, USA.
I've had good luck with the Duplicolor brand. It goes on really thin and takes multiple coats, but once it cures it's very tough.
Street racing is a mystery to most people, but I've got it figured out. If it blows up with a single 4, go dual quads. If that goes, inject it. And fix it fast.
[Re: 440newport]
#827060
10/11/10 12:58 AM
10/11/10 12:58 AM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
I don't know if it's the BESTest, but I use Plastikote and had good results with it.
[Re: dOoC]
#827061
10/11/10 01:02 AM
10/11/10 01:02 AM
Posts: 4,588 St. John's Newfoundland
440newport
COME to think about it ..... I believe that PK made that for TRW.
Doesn't it cover and dry almost like a powder-coat?
Yes, it covers really well with just 1 or 2 coats and is pretty durable I find.
[Re: dOoC]
#827065
10/11/10 05:04 PM
10/11/10 05:04 PM
Posts: 15,487 Florida
scratchnfotraction
duplicolor this go round plasticoat last go round no complants on either I used more than needed,about 4 full cans for a small block 2 cans on let flash dry for a couple hrs,hit it with other 2 cans nice and thick and tuff when cured by the heat
[Re: dOoC]
#827066
10/11/10 06:29 PM
10/11/10 06:29 PM
RapidRobert
& when you have it as clean as you can then drown it w 2 buck fifty cans of ether starting fluid. On a hot day it flashes off quickly & takes off lint from your cleaning rag & last traces of oils. Nothing better for a final cleaning & as you know w painting it's (mostly) all in the prep
[Re: scratchnfotraction]
#827067
10/11/10 07:10 PM
10/11/10 07:10 PM
Plasti-Kote # 226 Chrysler Orange.
Available at Car-Quest. (they usually have to order it!)
Covers great and lasted really well on my last street driven 440!
Here it is on the new one:
#827068
10/11/10 07:12 PM
10/11/10 07:12 PM
Better one of the paint un-obstructed by the decal: Valve cover was wirewheeled with a cup on an angle grinder, pits were filled, some wire tabs removed and it was wiped with wax and grease remover before being painted.
#827069
10/11/10 10:02 PM
10/11/10 10:02 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
DON'T use VHT. Looks great, until your carb spills a little gas on it, then it peels up like crazy. Who would make a paint that doesn't stand up to gasoline, then call it an "engine paint"?.... I guess VHT would! DAMHIK....
[Re: dOoC]
#827071
10/12/10 12:03 AM
10/12/10 12:03 AM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
TRW worked fine for me...or was it VHT?? crap, I don't remember...it was THREE letters! VHT I suppose.
[Re: 4BBodies]
#827073
10/12/10 10:12 AM
10/12/10 10:12 AM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
Oh, I also use Dupli Color aluminum primer for water pumps/intake manifolds. It is green. Covers like crap, but seems to hold up well on an engine.
