heater fan switch #824274
10/07/10 12:25 PM
10/07/10 12:25 PM
appleton,wis
moparrookie Offline OP
appleton,wis
as of late my 70 barracuda heater switch will not shut off. It goes from high to low and when I go to the off position it stays in low speed. Is there a spray that may fix tghe problem? I can not seem to fine a replacement.
Re: heater fan switch [Re: moparrookie] #824275
10/07/10 10:32 PM
10/07/10 10:32 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
If the switch itself is are worn out, you should replace it. Not worth the risk of a
Re: heater fan switch [Re: moparrookie] #824276
10/07/10 10:50 PM
10/07/10 10:50 PM
open it up & see if it looks fixable. You have to R&R it either way
Re: heater fan switch [Re: RapidRobert] #824277
10/07/10 11:17 PM
10/07/10 11:17 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
not my auctions but...
E body switch. Is this the one you are talking about? three terminal?
http://cgi.ebay.com/ebaymotors/MOPAR-70-...es#ht_500wt_921
I actually couldn't find one even on ebay at the time to replace mine. I actually found one from a later 70's truck I think for about 10 bucks, that had three terminals and looked like the same switch box with a different bracket. I carefully pried back the metal tabs that hold in the switch parts on both units and swapped out the terminal plate, spring, and sliding contacts. Took about 3 minutes and worked like a charm.
If you don't want to pick up the e-body one above, ebay "mopar blower switch" and you'll see what I mean about similar three terminal switch boxes on a lot of models, just different brackets and levers.
Ain't no spray going to fix an electrical circuit staying open.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: heater fan switch [Re: moparrookie] #824278
10/08/10 12:27 AM
10/08/10 12:27 AM
None
71rm23 Offline
71rm23  Offline
None
http://cgi.ebay.com/ebaymotors/NOS-MOPAR...sQ5fAccessories
Something like this? If not, contact this guy. I've bought alot of things from him and am pleased with everything. He's even had some parts he found for me a few times that no one seemed to have. Worth a shot, if you got a P/N.
Re: heater fan switch [Re: 71rm23] #824279
10/08/10 12:35 AM
10/08/10 12:35 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Check with Jim;
Re: heater fan switch [Re: Alaskan_TA] #824280
10/08/10 12:56 AM
10/08/10 12:56 AM
None
71rm23 Offline
71rm23  Offline
None
Check with Jim;
Forgot about Jim, thanks Barry
