not my auctions but...
E body switch. Is this the one you are talking about? three terminal?
http://cgi.ebay.com/ebaymotors/MOPAR-70-...es#ht_500wt_921I actually couldn't find one even on ebay at the time to replace mine. I actually found one from a later 70's truck I think for about 10 bucks, that had three terminals and looked like the same switch box with a different bracket. I carefully pried back the metal tabs that hold in the switch parts on both units and swapped out the terminal plate, spring, and sliding contacts. Took about 3 minutes and worked like a charm.
If you don't want to pick up the e-body one above, ebay "mopar blower switch" and you'll see what I mean about similar three terminal switch boxes on a lot of models, just different brackets and levers.
Ain't no spray going to fix an electrical circuit staying open.
