post your procharger setups #824244
10/07/10 11:27 AM
10/07/10 11:27 AM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, please post your procharger combos and performance. Cool to see what everyone is doing. LATER
Re: post your procharger setups [Re: 70VcodeCoronetRT] #824245
10/08/10 08:37 AM
10/08/10 08:37 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
All I hear are the crickets....
Re: post your procharger setups [Re: Dragula] #824246
10/08/10 09:52 AM
10/08/10 09:52 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
this is my old set-up. Nothing fancy. I did it all for around $2200 including carb and fuel system upgrades. Mild 440 (cast pistons) in a 67 cornet best et before boost 12.90 @ 104. (ran 13.0's in the heat) Best et after 6psi of boost 12.08 @114. The kit was for a SBC, I had the crank pulley re-drilled and cut/welded the mounting bracket to fit a BB mopar. car probably would have run easy 11's with a pulley change. Did it but sold the car before I could run it at 8psi.
Re: post your procharger setups [Re: Mr.Yuck] #824247
10/08/10 10:13 AM
10/08/10 10:13 AM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
I did a pro charger project for a customer along with help from Steve Morris.It was a 93 Dakota street driven 394ci,W5 heads,850 cfm pro system blow throw carb with a F1R.It weighted 3400lbs.
The dyno read 998hp with a safe tune up and it ran 9.27 @ 144 in street trim.
Re: post your procharger setups [Re: Hitman340] #824248
10/08/10 10:41 AM
10/08/10 10:41 AM
Dragula Offline
Dragula  Offline
I want more info on this beast that Mopar_Rich did recently... 2000hp on pump gas!
Re: post your procharger setups [Re: Dragula] #824249
10/08/10 12:38 PM
10/08/10 12:38 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
Looking for some real world bb street cruisers in the 650 700hp range.
Re: post your procharger setups [Re: 440forPOWER] #824250
10/08/10 01:20 PM
10/08/10 01:20 PM
Dragula Offline
Dragula  Offline
My N/A pump gas efi Hemi engine is over 700hp....And my engine builders mild N/A pump gas Hemi Charger is making 655hp...
Re: post your procharger setups [Re: Dragula] #824251
10/09/10 08:53 PM
10/09/10 08:53 PM
QLD Australia
Keith Black® Offline
QLD Australia
1500hp.
525 cu.in EFI. F2. Intercooled. 6-spd manual.
pump gas.
we're making front pulley/setup at present. all under-hood.
Darren Beale
Keith Black Racing Engines®
Re: post your procharger setups [Re: Keith Black®] #824252
10/09/10 08:54 PM
10/09/10 08:54 PM
QLD Australia
QLD Australia
..unlawful 4 link. rear setup. 345/30x19's
Darren Beale
Re: post your procharger setups [Re: Keith Black®] #824253
10/09/10 09:16 PM
10/09/10 09:16 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
my car, f-2,20lbs boost, bottom 8's 3300lbs, no intercooler
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: post your procharger setups [Re: Dragula] #824254
10/09/10 09:28 PM
10/09/10 09:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah but your N/A hemi costs 3x times what aboost wedge costs and doesn't need a ton of converter and can doesn't need to spin to 8k.
Re: post your procharger setups [Re: Mr.Yuck] #824255
10/10/10 11:20 AM
10/10/10 11:20 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I bet it's also FAR from what most of us would consider a street car.
My mild turbo 440 made the Hot Rod Power Tour from Dallas to Green Bay and back without missing a beat. It sucked down 87 octane and gave me 17 mpg.
Yeah, there are naturally aspirated engines making far more power but I bet the guys have far more money than I do in this one and they don't behave as nicely.
- Stu Harmon
Re: post your procharger setups [Re: feets] #824256
10/24/10 11:25 PM
10/24/10 11:25 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
nothing close to a street car but..........
old procharged setup
Outlaw 10.5 526ci, F3R procharged tfx hemi, Big Stuff 3 PTP RACING
Re: post your procharger setups [Re: 526ciduster] #824257
10/24/10 11:40 PM
10/24/10 11:40 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
new procharged setup.
Re: post your procharger setups [Re: 526ciduster] #824258
10/25/10 07:06 AM
10/25/10 07:06 AM
Dragula Offline
Dragula  Offline
Nice, I like it. If I only had the money. I would have the set-up Mopar Rich has in my Cuda.
Is it me, or does that new engine sit higher in the front.
Re: post your procharger setups [Re: Dragula] #824259
10/25/10 09:19 PM
10/25/10 09:19 PM
Mr440GSS Offline
Mr440GSS  Offline
D1SC, 440, stock Eddy heads, Torker II, Comp .488 hydraulic, 5 speed Tremec, 3.54 geared stock weight B body @ 8psi.
Ran 123mph and change, no need to post the ET, lol...
Re: post your procharger setups [Re: Mr440GSS] #824260
10/26/10 09:34 AM
10/26/10 09:34 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
looks fimiliar, same cam 224/234-465/488 no e-heads or 5 speed and only 6psi. never got to try the 8psi pulley. I think my 3.91's worked against me. ran 12.0's at 114.
Re: post your procharger setups [Re: 526ciduster] #824261
10/26/10 04:53 PM
10/26/10 04:53 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
How fast did you go with the stock block and -1's with that set-up?
One day I will have something cool here.
Re: post your procharger setups [Re: sdaurity] #824262
10/28/10 09:18 PM
10/28/10 09:18 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
4.95 @ 150mph at 3,200 lbs
still trying to tame the hemi. only a few aborted passes 5.14 131mph 3,300lbs
Re: post your procharger setups [Re: Dragula] #824263
10/28/10 09:20 PM
10/28/10 09:20 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
Its the angle of the picture i used the same motor and tranny mounts.
