1971 E body radiator support 22" - 26" #818321
09/30/10 09:55 AM
09/30/10 09:55 AM
CT
1932chrysler Offline OP
CT
What is the difference in the radiator support between 22" radiator & 26"?
has anyone modifed one?
changing from 318 to 340 engine
1971 challenger
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: 1971 E body radiator support 22" - 26" [Re: 1932chrysler] #818322
09/30/10 10:15 AM
09/30/10 10:15 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
You need this... http://cgi.ebay.com/ebaymotors/1970-74-C...sQ5fAccessories
It's the only piece that's different. Yes this fits an E Body
CHECK OUT MY NEW WEB SITE !
Re: 1971 E body radiator support 22" - 26" [Re: anlauto] #818323
09/30/10 10:45 AM
09/30/10 10:45 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Nope, the driver side is different too. But not much. I think its about 1/2" narrower. The slots in the radiator often let you use the stock 22" side as there is enough play. I have pics somewhere.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 1971 E body radiator support 22" - 26" [Re: RoadRunner] #818324
09/30/10 09:02 PM
09/30/10 09:02 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
I would use that conversion piece rather than changing the whole support; otherwise you lose your VIN.
Re: 1971 E body radiator support 22" - 26" [Re: 2fast4yourBrain] #818325
09/30/10 09:29 PM
09/30/10 09:29 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
Thats a good question....
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: 1971 E body radiator support 22" - 26" [Re: fireeng] #818326
09/30/10 09:31 PM
09/30/10 09:31 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
We should also ask if a 26" radiator from US Radiator will work and look somewhat stock.
thanks..
1971 Challenger
2013 Jeep Wrangler
Re: 1971 E body radiator support 22" - 26" [Re: 1932chrysler] #818327
10/01/10 11:30 AM
10/01/10 11:30 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1971 challenger
You do know that you can simply get a decent 22" rad and it will cool fine and there is no need to go to the 26" one, right?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 1971 E body radiator support 22" - 26" [Re: 2fast4yourBrain] #818328
10/01/10 11:45 AM
10/01/10 11:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He never said anything about ditching the original top crossbar , both sides are different, one would replace both sides if they wanted to do it right and reattach the original crossbar .
Re: 1971 E body radiator support 22" - 26" [Re: DPelletier] #818329
10/01/10 12:12 PM
10/01/10 12:12 PM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
1971 challenger
I think that is best route
On my parts gathering stage I have a 26" with the fan shroud from my other car.
But bought a 22" radiater/shroud that could be rodded out with the right # tanks, but may get a recore job for pieace of mind and think thats the best.
Picked that up along with a mint{looks NOS} 70 compleate jack/hook from Mark Nixon
Re: 1971 E body radiator support 22" - 26" [Re: 340SIX] #818330
10/01/10 02:03 PM
10/01/10 02:03 PM
DPelletier Offline
DPelletier  Offline
1971 challenger
I've found that many mopar guys are hung up on the 26" rad thing which is weird to me having come from owning many brand X cars. Mopars are 2 row in 22 or 26" widths...many of the GM cars I had had 4 row rads.
I'm sure it has to do with my background on HVAC coils, but I "did the math" before and my recored 22" should cool quite a bit better than a factory 26" rad.
I wouldn't dream of cutting on my #'s 440-6 car's factory 22" rad support so I simply had a high performance 3 row core installed with my original tanks for added cooling but I'm sure the 2 row would have been just fine as it was from the factory.
As far as the original poster's car; if a 22" rad is good enough for a 440-6, I'm sure it will be fine with a 340.
Re: 1971 E body radiator support 22" - 26" [Re: DPelletier] #818331
10/01/10 02:19 PM
10/01/10 02:19 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Where you live your 22" is probably fine... Where I live it isn't, wasn't when they were new & still isn't... Yeah it'll handle most days & it'll handle a smallblock..... But a big block on a real hot day forget about it... When I was in high school I accepted standing on the side of a country road with a boiling car as part of the price you pay.. Not anymore.... And as far as three & four core radiators go once the air has already picked up heat from the first row it picks up less on the second row... And even less on the third row... And obviously this only gets worse on really hot days... So a larger core means more air passes over the first row... I agree I wouldn't cut a V code car either but when building a clone like the post starter you have more options..
Oh and as far as a 340 car being ok with the small radiator I'd like to agree but I built a 340 Challenger thats in the Austin Tx area, it's got a 4 row 22" w/shroud that was rodded out when I built the engine, the 340 is a mild build with Edelbrock heads & when it's over 100 degrees it runs borderline to overheating... I think a 3 core 26" would likely be fine...
Re: 1971 E body radiator support 22" - 26" [Re: 1_WILD_RT] #818332
10/01/10 03:57 PM
10/01/10 03:57 PM
DPelletier Offline
DPelletier  Offline
Yes I understand that the 2nd row isn't as efficient as the first and on and on due to the increase in temperatures, but it is still quite possible to build a 22" rad with more cooling capacity than a 26" rad. As I said, I deal with this all the time on calculating the duct size and delta tee on hydronic coils (which are exactly the same thing). MOST of the cooling problems people have are to do with a host of other issues such as plugged cooling passages, incorrect timing/jetting, non-functioning fan clutches, etc. etc.
Also, many people are using inferior cores from scabby local shops. Even some of the cheapie "new" rads use really crappy cores (one of the magazines did a article on that a while back)
Anyway, the upshot is that my 3 row dimpled core 22" rad has more cooling capability than a factory 2 row 26" rad.....and I didn't have to touch any sheet metal, and I was able to use the original tanks and shroud.
Re: 1971 E body radiator support 22" - 26" [Re: DPelletier] #818333
10/01/10 07:13 PM
10/01/10 07:13 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
1971 Challenger
2013 Jeep Wrangler
Re: 1971 E body radiator support 22" - 26" [Re: fireeng] #818334
10/01/10 10:30 PM
10/01/10 10:30 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
Go aluminum, and you're done. you're modifing anyway... why not make it look pretty in the process !
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: 1971 E body radiator support 22" - 26" [Re: fireeng] #818335
10/01/10 11:12 PM
10/01/10 11:12 PM
you guys think this 22" will work.
http://www.usradiator.com/dodge-challenger-1970-72-v8-sb-aluminum-radiator.html
That site is kinda off it shows challengers from 66-69 as well as 70-72
Re: 1971 E body radiator support 22" - 26" [Re: fireeng] #818336
10/02/10 10:45 PM
10/02/10 10:45 PM
CT
CT
I don't think that particular radiator has enough capacity for the 340 high compression engine it only has 2 rows and 22" wide maybe if it had 3 rows (just a guess on my part).
I'm not sure why the Chrysler engineers decided that the 340 & 426 come standard with 26" radiator
I try not to second guess the engineering they only had all the cooling capacity numbers and testing to determine what will work.
Re: 1971 E body radiator support 22" - 26" [Re: 1932chrysler] #818337
10/02/10 11:35 PM
10/02/10 11:35 PM
Shows 2 wide rows think 1"
Re: 1971 E body radiator support 22" - 26" [Re: 340SIX] #818338
10/03/10 07:28 AM
10/03/10 07:28 AM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
how about this one. It appears to be available in 2, 3, or 4 rows. I'd keep the 22" if we can find out that will do the job, look some what stock and will be that much easier to install......Scott
http://www.usradiator.com/dodge-challenger-1970-72-v8-sb-radiator.html
1971 Challenger
2013 Jeep Wrangler
Re: 1971 E body radiator support 22" - 26" [Re: fireeng] #818339
10/03/10 09:08 AM
10/03/10 09:08 AM
CT
CT
Yes more rows will increase the cooling capacity I know you will need 3 or 4 rows read other posts for guidance especially the ones from warm weather climates
Also remember you have an automatic and the trans cooler requires some capacity to remove trans heat
IMO thicker is better if you have the room I never saw the car with engine in
