1971 E body radiator support 22" - 26"
#818321
09/30/10 09:55 AM
09/30/10 09:55 AM
Posts: 83 CT
1932chrysler
CT
What is the difference in the radiator support between 22" radiator & 26"? has anyone modifed one? changing from 318 to 340 engine 1971 challenger
1932 Chrysler CI Sedan 1956 Pontiac Catalina Sedan All Makes & Models Are Special
Re: 1971 E body radiator support 22" - 26"
[Re: RoadRunner]
#818324
09/30/10 09:02 PM
09/30/10 09:02 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
You need this... http://cgi.ebay.com/ebaymotors/1970-74-C...sQ5fAccessories
It's the only piece that's different. Yes this fits an E Body
Nope, the driver side is different too. But not much. I think its about 1/2" narrower. The slots in the radiator often let you use the stock 22" side as there is enough play. I have pics somewhere.
I would use that conversion piece rather than changing the whole support; otherwise you lose your VIN.
[Re: fireeng]
#818326
09/30/10 09:31 PM
09/30/10 09:31 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
We should also ask if a 26" radiator from US Radiator will work and look somewhat stock.
thanks..
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
[Re: 1932chrysler]
#818327
10/01/10 11:30 AM
10/01/10 11:30 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
You do know that you can simply get a decent 22" rad and it will cool fine and there is no need to go to the 26" one, right?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 2fast4yourBrain]
#818328
10/01/10 11:45 AM
10/01/10 11:45 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
He never said anything about ditching the original top crossbar , both sides are different, one would replace both sides if they wanted to do it right and reattach the original crossbar .
[Re: DPelletier]
#818329
10/01/10 12:12 PM
10/01/10 12:12 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I think that is best route On my parts gathering stage I have a 26" with the fan shroud from my other car. But bought a 22" radiater/shroud that could be rodded out with the right # tanks, but may get a recore job for pieace of mind and think thats the best. Picked that up along with a mint{looks NOS} 70 compleate jack/hook from Mark Nixon
[Re: DPelletier]
#818331
10/01/10 02:19 PM
10/01/10 02:19 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I've found that many mopar guys are hung up on the 26" rad thing which is weird to me having come from owning many brand X cars. Mopars are 2 row in 22 or 26" widths...many of the GM cars I had had 4 row rads.
I'm sure it has to do with my background on HVAC coils, but I "did the math" before and my recored 22" should cool quite a bit better than a factory 26" rad.
I wouldn't dream of cutting on my #'s 440-6 car's factory 22" rad support so I simply had a high performance 3 row core installed with my original tanks for added cooling but I'm sure the 2 row would have been just fine as it was from the factory.
As far as the original poster's car; if a 22" rad is good enough for a 440-6, I'm sure it will be fine with a 340.
Dave Where you live your 22" is probably fine... Where I live it isn't, wasn't when they were new & still isn't... Yeah it'll handle most days & it'll handle a smallblock..... But a big block on a real hot day forget about it... When I was in high school I accepted standing on the side of a country road with a boiling car as part of the price you pay.. Not anymore.... And as far as three & four core radiators go once the air has already picked up heat from the first row it picks up less on the second row... And even less on the third row... And obviously this only gets worse on really hot days... So a larger core means more air passes over the first row... I agree I wouldn't cut a V code car either but when building a clone like the post starter you have more options..
Oh and as far as a 340 car being ok with the small radiator I'd like to agree but I built a 340 Challenger thats in the Austin Tx area, it's got a 4 row 22" w/shroud that was rodded out when I built the engine, the 340 is a mild build with Edelbrock heads & when it's over 100 degrees it runs borderline to overheating... I think a 3 core 26" would likely be fine...
[Re: 1_WILD_RT]
#818332
10/01/10 03:57 PM
10/01/10 03:57 PM
DPelletier
Yes I understand that the 2nd row isn't as efficient as the first and on and on due to the increase in temperatures, but it is still quite possible to build a 22" rad with more cooling capacity than a 26" rad. As I said, I deal with this all the time on calculating the duct size and delta tee on hydronic coils (which are exactly the same thing). MOST of the cooling problems people have are to do with a host of other issues such as plugged cooling passages, incorrect timing/jetting, non-functioning fan clutches, etc. etc. Also, many people are using inferior cores from scabby local shops. Even some of the cheapie "new" rads use really crappy cores (one of the magazines did a article on that a while back)
Anyway, the upshot is that my 3 row dimpled core 22" rad has more cooling capability than a factory 2 row 26" rad.....and I didn't have to touch any sheet metal, and I was able to use the original tanks and shroud.
1974 'Cuda
[Re: fireeng]
#818334
10/01/10 10:30 PM
10/01/10 10:30 PM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
Go aluminum, and you're done. you're modifing anyway... why not make it look pretty in the process !
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
[Re: fireeng]
#818336
10/02/10 10:45 PM
10/02/10 10:45 PM
Posts: 83 CT
1932chrysler
CT
I don't think that particular radiator has enough capacity for the 340 high compression engine it only has 2 rows and 22" wide maybe if it had 3 rows (just a guess on my part). I'm not sure why the Chrysler engineers decided that the 340 & 426 come standard with 26" radiator I try not to second guess the engineering they only had all the cooling capacity numbers and testing to determine what will work.
[Re: fireeng]
#818339
10/03/10 09:08 AM
10/03/10 09:08 AM
Posts: 83 CT
1932chrysler
CT
Yes more rows will increase the cooling capacity I know you will need 3 or 4 rows read other posts for guidance especially the ones from warm weather climates Also remember you have an automatic and the trans cooler requires some capacity to remove trans heat IMO thicker is better if you have the room I never saw the car with engine in
