Is the aluminum 8 3/4 center section worth the $$$ #815859
09/27/10 04:08 PM
09/27/10 04:08 PM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
Is the aluminum center section for the 8 3/4 worth the extra $$$ it costs over a nodular one ?
Where is the cheapest place to get one ?
J.C. Childress (434) 665-9541
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: JC Childress] #815860
09/27/10 04:10 PM
09/27/10 04:10 PM
an8sec70cuda Offline
No, get a dana.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: JC Childress] #815861
09/27/10 04:48 PM
09/27/10 04:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a alum center but I bought it before they went
sky high on price.... if your car is light and have a
8 3/4 all set up for your car then maybe it is BUT if
the car is heavier then no its not worth it
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: JC Childress] #815862
09/27/10 05:30 PM
09/27/10 05:30 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The MP aluminum casting is a rip-off.
The new Yukon nodular iron casting with forged steel caps and billet adjusters is a deal.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: DoctorDiff] #815863
09/27/10 05:54 PM
09/27/10 05:54 PM
Big Island ,VA
Big Island ,VA
It would be a stock eliminator car, cant run a Dana in a Duster.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: JC Childress] #815864
09/27/10 06:11 PM
09/27/10 06:11 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Yes you can.
Nautilus Racing-
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: JC Childress] #815865
09/27/10 06:15 PM
09/27/10 06:15 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Let's see. A stock elem, car and I can reduce unsprung weight and have a stronger unit than stock. Seems like a no brainer to me. I also feel that the aluminum carrier is as stong as it needs to be to arrive at the point were the gears are going to fail no matter what else I do. If we could just get someone to make pro gears for them.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: Cuda367] #815866
09/27/10 06:22 PM
09/27/10 06:22 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Not legal in Stock
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: DoctorDiff] #815867
09/27/10 06:55 PM
09/27/10 06:55 PM
AndyF Online content
AndyF  Online Content
Cass, is the new Yukon casting lighter or heavier than the stock carrier?
It is too bad that MP messed up the pricing on the aluminum center section. If they had it priced reasonably, and if it was a finished part, it would be a cool thing to run.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: AndyF] #815868
09/27/10 07:01 PM
09/27/10 07:01 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The old Yukon nodular case was heavier than stock. The new version weighs about the same.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: AndyF] #815869
09/27/10 07:14 PM
09/27/10 07:14 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Why isn't it considered finished?
Yes, they messed up on the pricing.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: autoxcuda] #815870
09/27/10 07:17 PM
09/27/10 07:17 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The MP casting does not include adjusters.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: DoctorDiff] #815871
09/27/10 07:29 PM
09/27/10 07:29 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Geez....
It would have been almost better if MP never made an aluminum center. Since its out on the market, if someone could sell one for cheaper they would never attempt to make it since it's such an niche.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: DoctorDiff] #815872
09/27/10 07:34 PM
09/27/10 07:34 PM
The MP center section also doesn't have clearance for the higher gear ratios.
I wanted to get a MP center built up for Tim's car but the cost was just too high to justify the weight reduction. There were a lot cheaper ways to pull weight out of his car so we dropped that idea off the list.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: JC Childress] #815873
09/27/10 08:03 PM
09/27/10 08:03 PM
mi
V
vcummins Offline
vcummins  Offline
V
mi
If you can get one reasonable get one. i run one in top stock for years. As for the Dana you can run A Dana in stock elem. its A corporate rearend.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: AndyF] #815874
09/27/10 08:09 PM
09/27/10 08:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What kind of higher ratio can't you run in it?
I've seen a old magnesium M/T housing at a swap meet for I think under $400. Same dude's had it for while. It was awful roached up though. I'd consider it a piece of clay you would have to check every measurement on. And just plan to do some machining to it.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: autoxcuda] #815875
09/27/10 08:18 PM
09/27/10 08:18 PM
Eherenberg did a writeup on it in Mopar action and they had to grind the housing for the 2.94 gearset they were installing. Said 2.76's didn't look like they'd fit.
It was installation clearance they had a problem with on the pinion and not necessarily operating clearance.
Re: Is the aluminum 8 3/4 center section worth the $$$ #815876
09/27/10 10:37 PM
09/27/10 10:37 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
I had a new one I paid $400 for and sold it when I had guys begging to buy it for $800.
I had an M/T mag version that I had about $125 in and sold it when I was offered $400.
So I am still iron-only and plan to stay that way.
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: GregCon] #815877
09/27/10 10:40 PM
09/27/10 10:40 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
I like my Randy's ring and pinion aluminum center
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Is the aluminum 8 3/4 center section worth the $$$ [Re: BloFish] #815878
09/27/10 10:46 PM
09/27/10 10:46 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
what is the weight diff ? .. 11 lbs ?
NOT worth it ...IMO.
