Is the aluminum 8 3/4 center section worth the $$$
#815859
09/27/10 04:08 PM
09/27/10 04:08 PM
Posts: 411 Big Island ,VA
JC Childress
Big Island ,VA
Is the aluminum center section for the 8 3/4 worth the extra $$$ it costs over a nodular one ?
Where is the cheapest place to get one ?
J.C. Childress
(434) 665-9541
Re: Is the aluminum 8 3/4 center section worth the $$$
[Re: JC Childress]
#815860
09/27/10 04:10 PM
09/27/10 04:10 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
[Re: JC Childress]
#815861
09/27/10 04:48 PM
09/27/10 04:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I run a alum center but I bought it before they went sky high on price.... if your car is light and have a 8 3/4 all set up for your car then maybe it is BUT if the car is heavier then no its not worth it
[Re: DoctorDiff]
#815863
09/27/10 05:54 PM
09/27/10 05:54 PM
JC Childress
Big Island ,VA
It would be a stock eliminator car, cant run a Dana in a Duster.
J.C. Childress
(434) 665-9541
[Re: JC Childress]
#815865
09/27/10 06:15 PM
09/27/10 06:15 PM
Posts: 628 Denison,Ia.
Cuda367
Denison,Ia.
Let's see. A stock elem, car and I can reduce unsprung weight and have a stronger unit than stock. Seems like a no brainer to me. I also feel that the aluminum carrier is as stong as it needs to be to arrive at the point were the gears are going to fail no matter what else I do. If we could just get someone to make pro gears for them.
[Re: DoctorDiff]
#815867
09/27/10 06:55 PM
09/27/10 06:55 PM
Posts: 31,052 Oregon
AndyF
The MP aluminum casting is a rip-off.
The new Yukon nodular iron casting with forged steel caps and billet adjusters is a deal.
Cass, is the new Yukon casting lighter or heavier than the stock carrier?
It is too bad that MP messed up the pricing on the aluminum center section. If they had it priced reasonably, and if it was a finished part, it would be a cool thing to run.
[Re: AndyF]
#815869
09/27/10 07:14 PM
09/27/10 07:14 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Why isn't it considered finished?
Yes, they messed up on the pricing.
[Re: DoctorDiff]
#815871
09/27/10 07:29 PM
09/27/10 07:29 PM
autoxcuda
So Cal
The MP casting does not include adjusters.
Geez....
It would have been almost better if MP never made an aluminum center. Since its out on the market, if someone could sell one for cheaper they would never attempt to make it since it's such an niche.
[Re: AndyF]
#815874
09/27/10 08:09 PM
09/27/10 08:09 PM
autoxcuda
So Cal
The MP center section also doesn't have clearance for the higher gear ratios.
I wanted to get a MP center built up for Tim's car but the cost was just too high to justify the weight reduction. There were a lot cheaper ways to pull weight out of his car so we dropped that idea off the list.
What kind of higher ratio can't you run in it?
I've seen a old magnesium M/T housing at a swap meet for I think under $400. Same dude's had it for while. It was awful roached up though. I'd consider it a piece of clay you would have to check every measurement on. And just plan to do some machining to it.
[Re: autoxcuda]
#815875
09/27/10 08:18 PM
09/27/10 08:18 PM
Eherenberg did a writeup on it in Mopar action and they had to grind the housing for the 2.94 gearset they were installing. Said 2.76's didn't look like they'd fit.
It was installation clearance they had a problem with on the pinion and not necessarily operating clearance.
