Denso ultra mini alternator? #815348
09/26/10 10:27 PM
09/26/10 10:27 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Anyone know what vehicle (make, model, year, engine) that the Denso "ultra mini" 93mm alternator came on as OEM?
Thanks, Brian
Re: Denso ultra mini alternator? [Re: '72CudaRacer] #815349
09/27/10 05:30 AM
09/27/10 05:30 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
FWIW,
I got the 102mm mini from like a 87-90-ish? Chevy Nova/Spectrum with the single groove steel V-belt pulley. Got it from the junkyard. Tested fine. It is the same physically as powermaster p/n 8122/8128 6.78 lbs. 102 mm. ( http://www.powermastermotorsports.co...ternators.html ) They are not one wire stock. But they have an internal regulator.
I have yet to install it or really spend time trying to figure out the fabrication of the brackets.
I think the 93mm might be an industrial application (forklift?)??
This came from this thread: http://www.forabodiesonly.com/mopar/showthread.php?t=83923
I'm looking at adapting one off of a Toyota brand forklift. An older one off of a 7 series model are rated at 37amps. My plan is install it on my drag race car.
Re: Denso ultra mini alternator? [Re: autoxcuda] #815350
09/27/10 05:48 AM
09/27/10 05:48 AM
Finland
mafo Offline
mafo  Offline
Finland
I got mine from a nissan micra but I believe it s closer to the 102 mm model
here is a few to chose from
http://www.alternatorparts.com/FIT_Nippondenso_Alternators.htm
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Denso ultra mini alternator? [Re: mafo] #815351
09/27/10 06:55 AM
09/27/10 06:55 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
the ones i've used came off kubota diesel industrial engines.
Re: Denso ultra mini alternator? [Re: '72CudaRacer] #815352
09/27/10 09:52 AM
09/27/10 09:52 AM
GA
Boosted Offline
Boosted  Offline
GA
I am using a Mitsu alt... You can see it here on my motor.. Maybe not as small as you want but is smaller than the oem ver.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Denso ultra mini alternator? [Re: autoxcuda] #815353
09/27/10 11:47 AM
09/27/10 11:47 AM
AndyF Online content
AndyF  Online Content
I make a kit for the small Denso.
Re: Denso ultra mini alternator? [Re: AndyF] #815354
09/27/10 10:16 PM
09/27/10 10:16 PM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
Got mine from a 93 caravan
Re: Denso ultra mini alternator? [Re: RockChip] #815355
09/28/10 01:17 AM
09/28/10 01:17 AM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
not the ultra but works for me 89 4 runner
I was able to message my factory 360 brackets works great.
napa 138283 lifetime warranty 2138283 3 year
Re: Denso ultra mini alternator? [Re: AndyF] #815356
09/28/10 01:33 AM
09/28/10 01:33 AM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
got mine off a 89 4runner also they're a great upgrade... super easy to wire up....
Re: Denso ultra mini alternator? [Re: skep419] #815357
09/28/10 07:00 AM
09/28/10 07:00 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
How many amps is that one rated at?
Re: Denso ultra mini alternator? [Re: POS Dakota] #815358
09/28/10 09:03 AM
09/28/10 09:03 AM
USA eastern PA
340Bird Offline
340Bird  Offline
USA eastern PA
60 amps
Re: Denso ultra mini alternator? [Re: 340Bird] #815359
09/28/10 11:44 AM
09/28/10 11:44 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
do this use the 4 wire plug in the back if so could someone give the details of the wireing if possible...thanks mike
Re: Denso ultra mini alternator? [Re: earthmover] #815360
09/28/10 12:42 PM
09/28/10 12:42 PM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
Wiring goes like this.......
Re: Denso ultra mini alternator? [Re: marvo451] #815361
09/28/10 01:47 PM
09/28/10 01:47 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
thats what i was looking for thank you very much...mike
Re: Denso ultra mini alternator? [Re: '72CudaRacer] #815362
10/14/10 12:58 PM
10/14/10 12:58 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Back to the ultra mini:
I've looked for awhile now and am thinking it is probably the Denso 100211-4200 or maybe the 100211-6960 (with one of the mounting lugs removed)....as seen on page 16 of this document:
http://www.dixie-electric.com/catalog/LiftTrucksExchange.pdf
To arrive at that I matched up 50A, the B+ stud location, and the appearance of the sheetmetal cover on the back of the alt. I can't see the connector.
it may well be one of the other ones, or a hybrid....take your pick I guess It appears to me to be a power equipment (tractor/skid steer/forklift) type alternator, not a car alternator unless it's a mighty small car.
But then I'm still using a 78 amp squareback, and have kept electrical accessories to a minimum because of it....so you might not want to listen to me
Rich H.
Esse Quam Videri
