Re: Denso ultra mini alternator?
[Re: '72CudaRacer]
#815349
09/27/10 05:30 AM
09/27/10 05:30 AM
Posts: 27,453 So Cal
autoxcuda
So Cal
FWIW, I got the 102mm mini from like a 87-90-ish? Chevy Nova/Spectrum with the single groove steel V-belt pulley. Got it from the junkyard. Tested fine. It is the same physically as powermaster p/n 8122/8128 6.78 lbs. 102 mm. ( http://www.powermastermotorsports.co...ternators.html ) They are not one wire stock. But they have an internal regulator. I have yet to install it or really spend time trying to figure out the fabrication of the brackets. I think the 93mm might be an industrial application (forklift?)?? This came from this thread: http://www.forabodiesonly.com/mopar/showthread.php?t=83923 Quote:
I'm looking at adapting one off of a Toyota brand forklift. An older one off of a 7 series model are rated at 37amps. My plan is install it on my drag race car.
[Re: '72CudaRacer]
#815352
09/27/10 09:52 AM
09/27/10 09:52 AM
Posts: 2,648 GA
Boosted
GA
I am using a Mitsu alt... You can see it here on my motor.. Maybe not as small as you want but is smaller than the oem ver.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: RockChip]
#815355
09/28/10 01:17 AM
09/28/10 01:17 AM
Posts: 782 Minnesota
skep419
Minnesota
not the ultra but works for me 89 4 runner I was able to message my factory 360 brackets works great. napa 138283 lifetime warranty 2138283 3 year
[Re: skep419]
#815357
09/28/10 07:00 AM
09/28/10 07:00 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
How many amps is that one rated at?
[Re: '72CudaRacer]
#815362
10/14/10 12:58 PM
10/14/10 12:58 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Back to the ultra mini: I've looked for awhile now and am thinking it is probably the Denso 100211-4200 or maybe the 100211-6960 (with one of the mounting lugs removed)....as seen on page 16 of this document: http://www.dixie-electric.com/catalog/LiftTrucksExchange.pdfTo arrive at that I matched up 50A, the B+ stud location, and the appearance of the sheetmetal cover on the back of the alt. I can't see the connector. it may well be one of the other ones, or a hybrid....take your pick I guess It appears to me to be a power equipment (tractor/skid steer/forklift) type alternator, not a car alternator unless it's a mighty small car. But then I'm still using a 78 amp squareback, and have kept electrical accessories to a minimum because of it....so you might not want to listen to me
Rich H.
Esse Quam Videri
