360 cam and gear drive suggestions #814456
09/25/10 11:28 PM
09/25/10 11:28 PM
Hurricane, WV
moparsrule Offline OP
Hurricane, WV
I have a 74 Dart with a numbers matching 360. The engine has been rebuilt but it is throwing oil out of the dip stick. I am planning on having the engine gone through to check it out and I want to install a new cam and I was wondering what I should go with. I also like the sound of a gear drive, has anybody had any experience with a gear drive versus a double roller chain? Here is some info on the car that might help in the cam choice. 360 with factory intake and exhaust manifolds, 2 1/2" TTI exhaust with H pipe and flowmasters, going to install an 8 3/4 rear with 410 gears and may install around a 2500 stall. I want the cam to have a good choppy sound but I want it to perform as well as I can get it to. Thank you for all of your suggestions.
Re: 360 cam and gear drive suggestions [Re: moparsrule] #814457
09/25/10 11:46 PM
09/25/10 11:46 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The only benifit to a geardrive is it can be adjusted easier. If you want one even easier than that then you need a belt drive. I have seen several dyno tests with the different drives and never seen more than 2-3 hp differance if the cam timing was no changed.
Re: 360 cam and gear drive suggestions [Re: moparsrule] #814458
09/26/10 03:37 AM
09/26/10 03:37 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
I've heard that the benefit of gear drive is the accuracy of setting your timing and it hold it. You won't get the ever so slight variation you get with a chain. Thing is, MOST people that run these don't set their timing that good to begin with. If you want it for the sound, then thats a different story. Thats what I lot of people get them for. Me, I'll run a supercharger to get that sound
Re: 360 cam and gear drive suggestions [Re: None2Slow] #814459
09/26/10 06:44 AM
09/26/10 06:44 AM
IN
ahy Offline
ahy  Offline
IN
On a SB you can fit the chain tensioner from the later Magnum's. This is a really good setup and takes out any slop in the chain. Mancini can fix you up.
If you want a gear drive, the Milodon idler type is supposed to be the best. There are less expensive offerings but I'd take the chain first.
Re: 360 cam and gear drive suggestions [Re: ahy] #814460
09/26/10 09:34 AM
09/26/10 09:34 AM
scratchnfotraction Offline
the cheaper CAT gear drive are getting some good feed back from a few that are running them,they are like 120$ compaird to 300-400 $ for name brands
the hughes whiplash has a nice lump sound and is a great performance/cruzer cam
Re: 360 cam and gear drive suggestions [Re: scratchnfotraction] #814461
09/26/10 01:25 PM
09/26/10 01:25 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My kid has Pete Jackson in his BB.After probally 15K street and strip models no problems at all.Rocky
Chrysler Firepower
Re: 360 cam and gear drive suggestions [Re: therocks] #814462
09/26/10 11:48 PM
09/26/10 11:48 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
cam, hard to go wrong with an XE262 or XE268....
2017 Grand Cherokee Overland
Re: 360 cam and gear drive suggestions [Re: patrick] #814463
09/27/10 09:58 PM
09/27/10 09:58 PM
Hurricane, WV
Hurricane, WV
Will these cams have a good lope to them? Will they work fine with factory exhaust manifolds? And should I use a stall converter other than stock? Thanks for the help.
Re: 360 cam and gear drive suggestions [Re: moparsrule] #814464
09/28/10 09:13 AM
09/28/10 09:13 AM
the whiplash has a nice lumppy lump lump sound to it
if you look on hughes web page the have a member(lew) with his 340 on there to advertize it
you can hear it and see it
not sure on the 2 Patrick suggested,I do know they work good
I run a lunati 292/292 in a 360 and it has a very nice choppy chop chop as well
Re: 360 cam and gear drive suggestions [Re: moparsrule] #814465
09/28/10 11:05 AM
09/28/10 11:05 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if it's a stock long block, low compression 360, the 262 will have a bit of lope if you set the idle at about 700 RPM in gear (will pull ~11-12" vaccuuum)....it works sweet with a converter that stalls in the 2300-2500 RPM range. pulls like a mother.....been there, done that, bought the T-shirt, but I was also using an eddie 600, eddie air gap, and headers.
XE268 will be a little rougher idle, and lower torque on the low end with a little more HP up top (say, north of 5500 RPM) in the same motor as the XE262. I'd probably up the stall speed another 200 RPM or so.
I strongly recommend the summit headers. good quality, cheap price, will make a good 15-20 lb ft more torque throughout the rev range.
Re: 360 cam and gear drive suggestions [Re: patrick] #814466
09/28/10 09:49 PM
09/28/10 09:49 PM
Hurricane, WV
Hurricane, WV
Thanks for all the good advise.
