Re: 360 cam and gear drive suggestions
[Re: moparsrule]
#814457
09/25/10 11:46 PM
09/25/10 11:46 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The only benifit to a geardrive is it can be adjusted easier. If you want one even easier than that then you need a belt drive. I have seen several dyno tests with the different drives and never seen more than 2-3 hp differance if the cam timing was no changed.
[Re: scratchnfotraction]
#814461
09/26/10 01:25 PM
09/26/10 01:25 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
My kid has Pete Jackson in his BB.After probally 15K street and strip models no problems at all.Rocky
Chrysler Firepower
[Re: therocks]
#814462
09/26/10 11:48 PM
09/26/10 11:48 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
cam, hard to go wrong with an XE262 or XE268....
[Re: patrick]
#814463
09/27/10 09:58 PM
09/27/10 09:58 PM
Posts: 28 Hurricane, WV
moparsrule
Hurricane, WV
Will these cams have a good lope to them? Will they work fine with factory exhaust manifolds? And should I use a stall converter other than stock? Thanks for the help.
[Re: moparsrule]
#814464
09/28/10 09:13 AM
09/28/10 09:13 AM
Posts: 15,487 Florida
scratchnfotraction
the whiplash has a nice lumppy lump lump sound to it if you look on hughes web page the have a member(lew) with his 340 on there to advertize it you can hear it and see it not sure on the 2 Patrick suggested,I do know they work good I run a lunati 292/292 in a 360 and it has a very nice choppy chop chop as well
[Re: moparsrule]
#814465
09/28/10 11:05 AM
09/28/10 11:05 AM
patrick
Grand Haven, MI
if it's a stock long block, low compression 360, the 262 will have a bit of lope if you set the idle at about 700 RPM in gear (will pull ~11-12" vaccuuum)....it works sweet with a converter that stalls in the 2300-2500 RPM range. pulls like a mother.....been there, done that, bought the T-shirt, but I was also using an eddie 600, eddie air gap, and headers.
XE268 will be a little rougher idle, and lower torque on the low end with a little more HP up top (say, north of 5500 RPM) in the same motor as the XE262. I'd probably up the stall speed another 200 RPM or so.
I strongly recommend the summit headers. good quality, cheap price, will make a good 15-20 lb ft more torque throughout the rev range.
