Open a trunk without a key?
#807610
09/18/10 10:47 PM
09/18/10 10:47 PM
Posts: 2,190 SW MO
closer9
SW MO
Anyone know a good way to open a trunk without a key? Friend lost his key. Thinking about drilling out the lock, don't know of any better way. I'm assuming drill in far enough to gut the cylinder, then use a screwdriver to pop the latch?
Daily: '19 Frontier 4WD Belle: '67 Belvedere Convertible, 318/727 in Go ManGo! Other: '64 C10, 283/3 on the tree
Re: Open a trunk without a key?
[Re: closer9]
#807619
09/19/10 06:26 PM
09/19/10 06:26 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
if button doesn't work simply find the wire down the carpet or kick panel area and power it up with a jumper wire from some batt source ( fuse box will work )
plug tipically must be around that area
normally, is a black wire
[Re: NachoRT74]
#807620
09/19/10 10:01 PM
09/19/10 10:01 PM
Posts: 2,190 SW MO
closer9
SW MO
Um... Thanks, but let's just forget we had this conversation...
[Re: OzHemi]
#807624
09/19/10 11:22 PM
09/19/10 11:22 PM
Posts: 2,190 SW MO
closer9
SW MO
Nope, still no key... and nothing too exciting in there...
[Re: NachoRT74]
#807626
09/20/10 11:51 AM
09/20/10 11:51 AM
Posts: 4,046 Minnesota
72blubird
Minnesota
Reminds of my son in the road runner "Dad put the window down" "What? do it yourself" "There is no button" "That's what the cranks for" "Oh"
What was I thinking....
