Open a trunk without a key? #807610
09/18/10 10:47 PM
09/18/10 10:47 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Anyone know a good way to open a trunk without a key? Friend lost his key. Thinking about drilling out the lock, don't know of any better way. I'm assuming drill in far enough to gut the cylinder, then use a screwdriver to pop the latch?
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Open a trunk without a key? [Re: closer9] #807611
09/18/10 10:52 PM
09/18/10 10:52 PM
In a van, down by the river
jmf340 Offline
jmf340  Offline
what model car are you talking about?
Got Mopar???
Re: Open a trunk without a key? [Re: closer9] #807612
09/18/10 10:56 PM
09/18/10 10:56 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Depending on what it is...
Pull the back seat, and use every extension you have with a socket to un bolt the latch/catch.
Re: Open a trunk without a key? [Re: OzHemi] #807613
09/18/10 11:01 PM
09/18/10 11:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Like Oz says; or if you can, squeeze through the package tray bracing to the trunk lock and turn the lock. Some will take a large screwdriver, some need a pair of channel-locks.
Or, call a locksmith.
Re: Open a trunk without a key? [Re: topside] #807614
09/18/10 11:06 PM
09/18/10 11:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Standard screwdriver with a slim point taped to a broom handle works for most old Mopars.
Re: Open a trunk without a key? [Re: Alaskan_TA] #807615
09/18/10 11:12 PM
09/18/10 11:12 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Early 80's 5th Ave...
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Open a trunk without a key? [Re: closer9] #807616
09/19/10 12:12 PM
09/19/10 12:12 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
when all else fails use a BFH... ..I would do the in to the back seat way...
Re: Open a trunk without a key? [Re: closer9] #807617
09/19/10 12:51 PM
09/19/10 12:51 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Fifth ave? No button for elec release?
Re: Open a trunk without a key? [Re: buildanother] #807618
09/19/10 02:46 PM
09/19/10 02:46 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
I didn't think about that. I assume it doesn't work. Otherwise we may both be idiots, but I will have to check now...
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Open a trunk without a key? [Re: closer9] #807619
09/19/10 06:26 PM
09/19/10 06:26 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
if button doesn't work simply find the wire down the carpet or kick panel area and power it up with a jumper wire from some batt source ( fuse box will work )
plug tipically must be around that area
normally, is a black wire
Re: Open a trunk without a key? [Re: NachoRT74] #807620
09/19/10 10:01 PM
09/19/10 10:01 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Um...
Thanks, but let's just forget we had this conversation...
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Open a trunk without a key? [Re: closer9] #807621
09/19/10 10:01 PM
09/19/10 10:01 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Why ?
Was the trunk key still in the lock ?
Re: Open a trunk without a key? [Re: OzHemi] #807622
09/19/10 10:36 PM
09/19/10 10:36 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I bet he found Jimmy Hoffa inside......
Re: Open a trunk without a key? [Re: Alaskan_TA] #807623
09/19/10 10:46 PM
09/19/10 10:46 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Aaaaarrrgggghhhh....or pirate booty!
Re: Open a trunk without a key? [Re: OzHemi] #807624
09/19/10 11:22 PM
09/19/10 11:22 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Nope, still no key... and nothing too exciting in there...
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Open a trunk without a key? [Re: closer9] #807625
09/20/10 01:16 AM
09/20/10 01:16 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
but the button, works
Re: Open a trunk without a key? [Re: NachoRT74] #807626
09/20/10 11:51 AM
09/20/10 11:51 AM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
Reminds of my son in the road runner
"Dad put the window down"
"What? do it yourself"
"There is no button"
"That's what the cranks for"
"Oh"
What was I thinking....
Re: Open a trunk without a key? [Re: 72blubird] #807627
09/21/10 09:39 PM
09/21/10 09:39 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Yep. I loaned a pickup to a girl at work for the weekend. Monday morning she thanked me, but complained that they would build a vehicle with windows that don't roll down. I showed her the window cranks....
