Cylinder heads #804766
09/18/10 01:58 PM
09/18/10 01:58 PM
Cen Fla
j3wbagell Offline OP
Cen Fla
Anyone have advice on where to find a good set of heads?
Also has anyone had difficulty getting to the screws on the headers, they seem very close to the tubing and looks like a ratchet is necessary.
Re: Cylinder heads [Re: j3wbagell] #804767
09/18/10 02:02 PM
09/18/10 02:02 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
It would help to know what engine and what headers? What are you looking for in heads? There are all kinds of different ones for different uses. Yes most header bolts are hard to get to.
Re: Cylinder heads [Re: j3wbagell] #804768
09/18/10 02:04 PM
09/18/10 02:04 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Make sure you are using header bolts..with small heads...usually need an open end wrench to tighten them up..
and yes..good head is hard to find...
and what kinds of heads are you looking for...small block big block ..hemis...slant 6?
Tony
70 AARCuda Vitamin C
Re: Cylinder heads [Re: j3wbagell] #804769
09/18/10 02:05 PM
09/18/10 02:05 PM
Under My Car
Mopar_Country Offline
Under My Car
What engine?
When I installed mine on my 318 in an A body I found a variety was necessary. Ratchet with different length extensions, combination wrenches both short and long made the job a little less difficult.
Re: Cylinder heads [Re: Mopar_Country] #804770
10/16/10 04:45 PM
10/16/10 04:45 PM
Cen Fla
Cen Fla
Motor is a small block 318. I need to tap the first hole and bolt the headers back in. Extra lazy and thought about buying a smaller bore bole and rtv sealing it into the head. Would y'all recommend a new head? or should i take the SB out put in a 440 BB with new headers and intake?
Any thoughts according to the rtv?
Re: Cylinder heads [Re: j3wbagell] #804771
10/16/10 04:53 PM
10/16/10 04:53 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
That wont work. Repair the threads.
Re: Cylinder heads [Re: j3wbagell] #804772
10/16/10 04:55 PM
10/16/10 04:55 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Wht not buy a heli coil kit and fix the hole. RTV won't work or at least for not very long!! TAKING A SHORT CUT IS THE QUICKEST WAY TO THE PLACE YOU DID NOT WANT TO GO.
Re: Cylinder heads [Re: babarracuda] #804773
10/16/10 04:59 PM
10/16/10 04:59 PM
Cen Fla
Cen Fla
My problem is how close the bolts are to the header tubings. If it was easy to get to I'd be on the road already. I had it at a friends house for repair but he was unsuccessful in getting the headers off. So even if I buy new heads, taking off the headers is still going to be a chore.
Is it possible to tap and dye with out taking all the springs out?
how much pressure is going on in those blocks?
Re: Cylinder heads [Re: j3wbagell] #804774
10/16/10 06:50 PM
10/16/10 06:50 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Springs? Pressure?
Re: Cylinder heads [Re: Todd] #804775
10/16/10 07:44 PM
10/16/10 07:44 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Working on cars is hard work. Maybe you should take it to a shop.
Re: Cylinder heads [Re: 469runner] #804776
10/16/10 07:53 PM
10/16/10 07:53 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
after reading this post,,,, I need another beer
I am truckless..
Re: Cylinder heads [Re: 340SHORTY] #804777
10/16/10 08:11 PM
10/16/10 08:11 PM
Grand Prairie,Texas
Grand Prairie,Texas
I'm sorry but if you can't figure out how to get a simple header out and helicoil the stripped hole there is no way in hell you're going to be able to do a big block swap.
Re: Cylinder heads [Re: stumpy] #804778
10/16/10 08:48 PM
10/16/10 08:48 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm thinking
Kevin
Re: Cylinder heads [Re: Twostick] #804779
10/16/10 08:54 PM
10/16/10 08:54 PM
md
mopars4ever Offline
mopars4ever  Offline
md
ProMax had a pair of J heads redone at a very fair price. Check under small block parts for sale. Plus they are a sponsor here.
Re: Cylinder heads [Re: mopars4ever] #804780
10/16/10 10:00 PM
10/16/10 10:00 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Ok, my head is spinning from all this.
Scott
1969 Super Bee, 383/4 speed
Re: Cylinder heads [Re: StukaJU87] #804781
10/17/10 09:24 AM
10/17/10 09:24 AM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I think he means how much water pressure, and the answer is enough to make it leak if you don't fix it right! These young guys.......ok, my advice, just figure it out, go on Google and read how to's........then do it, fixing a stud is a 15 minute job for God's sake. And I agree with the post above, you need to do a LOT more "hands on" work before you even consider an engine swap. And buy an overhaul manual. (Ebay) Engines don't just fall in place by themselves......... just my
Re: Cylinder heads [Re: 4BBodies] #804782
10/17/10 04:38 PM
10/17/10 04:38 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Newbies need to take a deep breath and describe the problem clearly and intelligently- no text dialog and slang. Its bad when people think a post is a prank because its written SO BAD!
Keep old mopars alive.
Re: Cylinder heads [Re: 2boltmain] #804783
10/17/10 06:28 PM
10/17/10 06:28 PM
A small/thin open end wrench that has the 1 end turned 45 or 90 deg will help you. Do you have bolts or studs? If bolts which are notorious leakers, on the 1 that is leaking you might get an OE type stud that has the shoulder in the middle and this might solve it without resorting to a helicoil (do put some sealant on the inner coarse threads). You might be able to just take out the 1 bolt that is leaking & replace it w a trimmed OE stud & leave everything else in place depending on how much clearance you have. You can trim the outer fine threaded section of it for a better fit (mockup/measure/trim it ahead of time). You only need enough threads there for the nut to fit flush and any more is a waste and for sure will hit a pri tube. All BB head header bolt holes are wet so drain a gallon of coolant 1st. Good luck w it. EDIT shoot a quick shot of starting fluid into the hole to clean the head threads so your choice of gasket cement on the stud threads will seal better
