Re: Cylinder heads
[Re: j3wbagell]
#804768
09/18/10 02:04 PM
09/18/10 02:04 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Make sure you are using header bolts..with small heads...usually need an open end wrench to tighten them up..
and yes..good head is hard to find...
and what kinds of heads are you looking for...small block big block ..hemis...slant 6?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Cylinder heads
[Re: j3wbagell]
#804769
09/18/10 02:05 PM
09/18/10 02:05 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
Anyone have advice on where to find a good set of heads?
What engine?
Also has anyone had difficulty getting to the screws on the headers, they seem very close to the tubing and looks like a ratchet is necessary.
When I installed mine on my 318 in an A body I found a variety was necessary. Ratchet with different length extensions, combination wrenches both short and long made the job a little less difficult.
Re: Cylinder heads
[Re: j3wbagell]
#804772
10/16/10 04:55 PM
10/16/10 04:55 PM
Posts: 1,465 Carson City, NV
babarracuda
Carson City, NV
Wht not buy a heli coil kit and fix the hole. RTV won't work or at least for not very long!! TAKING A SHORT CUT IS THE QUICKEST WAY TO THE PLACE YOU DID NOT WANT TO GO.
Re: Cylinder heads
[Re: babarracuda]
#804773
10/16/10 04:59 PM
10/16/10 04:59 PM
Posts: 149 Cen Fla
j3wbagell
Cen Fla
My problem is how close the bolts are to the header tubings. If it was easy to get to I'd be on the road already. I had it at a friends house for repair but he was unsuccessful in getting the headers off. So even if I buy new heads, taking off the headers is still going to be a chore. Is it possible to tap and dye with out taking all the springs out? how much pressure is going on in those blocks?
Re: Cylinder heads
[Re: j3wbagell]
#804774
10/16/10 06:50 PM
10/16/10 06:50 PM
Posts: 1,377 Ohio
Todd
Ohio
Springs? Pressure?
Re: Cylinder heads
[Re: 4BBodies]
#804782
10/17/10 04:38 PM
10/17/10 04:38 PM
Posts: 4,786 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Newbies need to take a deep breath and describe the problem clearly and intelligently- no text dialog and slang. Its bad when people think a post is a prank because its written SO BAD!
Keep old mopars alive.
Re: Cylinder heads
[Re: 2boltmain]
#804783
10/17/10 06:28 PM
10/17/10 06:28 PM
RapidRobert
A small/thin open end wrench that has the 1 end turned 45 or 90 deg will help you. Do you have bolts or studs? If bolts which are notorious leakers, on the 1 that is leaking you might get an OE type stud that has the shoulder in the middle and this might solve it without resorting to a helicoil (do put some sealant on the inner coarse threads). You might be able to just take out the 1 bolt that is leaking & replace it w a trimmed OE stud & leave everything else in place depending on how much clearance you have. You can trim the outer fine threaded section of it for a better fit (mockup/measure/trim it ahead of time). You only need enough threads there for the nut to fit flush and any more is a waste and for sure will hit a pri tube. All BB head header bolt holes are wet so drain a gallon of coolant 1st. Good luck w it. EDIT shoot a quick shot of starting fluid into the hole to clean the head threads so your choice of gasket cement on the stud threads will seal better
