Re: Help me build a blower motor
[Re: galen]
#803714
09/17/10 02:58 PM
09/17/10 02:58 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You mean an actual boat, not just a monster C body, right?
[Re: Fury Fan]
#803719
09/21/10 12:22 AM
09/21/10 12:22 AM
DaytonaTurbo
Manitoba, Canada
Roots has far fewer options for an aftercooler (if any?).
Roots supercharged setups use an air-water intercooler which is sandwiched between the intake manifold and the supercharger. Would work very well in a boat because you could run it off cool lake water.
[Re: galen]
#803720
09/21/10 10:29 AM
09/21/10 10:29 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
Thanks for the links. I am ordering as soon as I leave here. And no I have not ruled out a turbo. Can a turbo engine be made to come up instantly on power though as I would need in the boat?
Turbos will always require some initial exhaust flow before they begin to build boost; a Roots starts immediately (but it's still a function of engine RPM). I don't have a feel for how long that would take in a boat compared to a car, but 'desirable' streetcar installations have boost start to build around ~3000rpm. How quickly does a boat engine hit 3000 RPM when going from idle to WOT?
There's the tradeoff, though, that the Roots will leach more HP off the crank than the turbo does via exh backpressure. The turbo's advantage there would allow you to perhaps use a slightly smaller turbo (which would limit overall HP) but build boost sooner. As an example of what I mean: large turbo - 800 hp Roots - 800hp - 50 lost at crank = 750 slightly smaller turbo, quicker boost - 750 hp
All my theorizing aside, I highly recommend that you visit here: http://www.theturboforums.com/smf/index.php?board=39.0
[Re: galen]
#803721
09/27/10 08:54 PM
09/27/10 08:54 PM
Posts: 78 tampa florida
elephant express
tampa florida
Galen, If It helps I have a Magnesium SSI 14:71 just set up for gas that is striped and out side is show polished with 60 degree rotors for $2500.00 and I have a few stroker cranks that are machined and ready to go. I'll have to look they have been under the bench for years. One is a Bryant. One has 3" mains 2.2 rods and the other is 2.2 rod and I think .020 under stock. I'll relook if you need one. I have $1500.00 in each crank but I'll take $700.00 per crank. Both top fuel Hemi cranks. Thanks Joe 600Hemi@tampabay.rr.com
