TIRE/RIM FITMENT #803456
09/16/10 09:20 PM
09/16/10 09:20 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Ok guys...I know I have been DRAGGING this topic around for a few weeks but I just did some measuring tonight and want to see what you guys think.
Ive been running 15"x8" rim with 4.5 back space with 5/16" spacer on the driver side and 7/16" on the pass side. Tonight I put them both on the pass side to see where the tire would sit. I now have atleast 1/2" maybe even 5/8" between the bulge of the QTP and the leaf. With the SS springs,the car sits high enough and I have plenty of room on the outside.
My question is this....I want to get a 10" rim but what back space??
Re: TIRE/RIM FITMENT [Re: MIKES_DUSTER] #803457
09/17/10 12:09 AM
09/17/10 12:09 AM
41 people look at my post and NO ONE can respond?????
Re: TIRE/RIM FITMENT [Re: MIKES_DUSTER] #803458
09/17/10 12:18 AM
09/17/10 12:18 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
think ARI440 has 10s on his duster but don't the BS on them.
Re: TIRE/RIM FITMENT [Re: MIKES_DUSTER] #803459
09/17/10 12:36 AM
09/17/10 12:36 AM
Do the math, to keep the same relations of the rim and tire sidewall to the springs and body panels requires adding half the width of the new rim width to the back spacing 4 8/16 + 5/16 +7/16 = 4 20/16 = 5 4/16 or 5 1/4, right Add one more inch for the width = 6 1/4 so the nearest off the shelf choice is probally 10x6.5 Keep the spacers handy BTW, always count on the section width being wider than you think it will when putting the same tire on a wider rim BTW, I use 10 x 5.5 x 15 and 12x 6.5x 15 on my Duster, I did have the housing narrowed down to one inch narrower than the stock 8 3/4 A bodys, I think I did keep the small A body rear brakes and the axle to brake backing plates spacing the same as the stock A body 8 3/4 are.
Re: TIRE/RIM FITMENT [Re: Randy..] #803460
09/17/10 01:04 AM
09/17/10 01:04 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
5 inch back space
this is with a dana 60
I think its 53 inch long
stock location caltrac setup
1.39 9.85 - 137 mph
Re: TIRE/RIM FITMENT [Re: MIKES_DUSTER] #803461
09/17/10 08:26 AM
09/17/10 08:26 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Re: TIRE/RIM FITMENT [Re: topbrent] #803462
09/17/10 08:38 AM
09/17/10 08:38 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Mike, I have 275/60-15 street radials on 8'' rims with 4.5'' backspace for the street and hoping to fit 15x10 rims with the same tyres on a 5 1/2'' backspace for the drags. Rob.
Re: TIRE/RIM FITMENT [Re: MIKES_DUSTER] #803463
09/17/10 09:03 AM
09/17/10 09:03 AM
Lehigh Acres, Florida
rickstershemi Offline
5.25 BS is what your going to need with a 10" rim according to your measurements with both spacers
Rickster
Re: TIRE/RIM FITMENT [Re: MIKES_DUSTER] #803464
09/17/10 10:13 AM
09/17/10 10:13 AM
NC
440Jim Offline
440Jim  Offline
NC
As CAB mentioned, the section width will be wider with the wider rim, so I think you will have fit problems unless you have room on the outside and move the tire centerline that direction. I can only guess (rough) the section width will be 1" wider, so 1/2" on each side.
When you said you had 1/2" clearance from the leaf spring on the passenger side, was this with no spacer? If the 1/2" clearance was using both spacers, ignore the calcs below.
I can't be sure, but here is my guess:
8" rim 4.5 BS = 10" rim 5.5 BS for same tire centerline.
Account for section width increase, 5.0 BS
Optional increase space from leaf from 1/2" to 1", 4.5 BS
But do you have room on the outside to move the tire centerline (1") this much? ie 1" centerline plus 1/2" section width will reduce outside clearance by 1.5".
Also remember, if you guess wrong with too much BS (5.0"), you can space it out. But if you guess wrong with not enough (4.5"), you are stuck.
