Magnum Force or PST?
#800539
09/13/10 09:20 PM
09/13/10 09:20 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
Both Magnum Force and PST offer 1-pc 2" drop spindles for B Bodies. As they're priced around the same I was wondering if anyone knows whether there are any differences in the quality of the parts??? Help appreciated Darren
-------------------------------- Darren Beale Keith Black Racing Engines®
Re: Magnum Force or PST?
[Re: DoctorDiff]
#800544
09/22/10 11:48 AM
09/22/10 11:48 AM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Are they the same dropped spindles that Fat Man sold for the FMJ bodies?
[Re: feets]
#800545
09/22/10 01:36 PM
09/22/10 01:36 PM
Posts: 27,478 So Cal
autoxcuda
So Cal
No, absolutely not.
Those are are welded up from thick flat stock with a spindle pressed and welded into the center. Some of the outside dimensions of those can be a little goofy too, but really the issue is they do not seem very stout.
I can't think of any reason anyone should be buying a Fat Man spindles for similar price with the cast iron ones out now.
[Re: DoctorDiff]
#800547
09/22/10 08:28 PM
09/22/10 08:28 PM
Posts: 7,664 IN
ahy
IN
They are a cast piece. Machining looks good, but some of the dimensions are off. You must shim (aftermarket) caliper brackets that mount to the outside face of the knuckle.
In addition, the tire contacts the tie rod if you run much wheel backspacing.
If I'm not mistaken, the originals are forged. A cast version will have meaningfully less strength... sounds like the fabbed versions have less as well.
[Re: autoxcuda]
#800550
09/23/10 03:33 AM
09/23/10 03:33 AM
Keith Black®
QLD Australia
I have the fatman spindles and am throwing them out. My engineer reckons they are unsafe (multiple pieces and welded etc), hence checking for one-piece replacements. I thought MF where forged ...? Hmmmm
