Magnum Force or PST? #800539
09/13/10 09:20 PM
09/13/10 09:20 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
Both Magnum Force and PST offer 1-pc 2" drop spindles for B Bodies.
As they're priced around the same I was wondering if anyone knows whether there are any differences in the quality of the parts???
Help appreciated
Darren
Darren Beale
Keith Black Racing Engines®
Re: Magnum Force or PST? [Re: Keith Black®] #800540
09/13/10 09:22 PM
09/13/10 09:22 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
They are the same part.
Re: Magnum Force or PST? [Re: DoctorDiff] #800541
09/13/10 11:39 PM
09/13/10 11:39 PM
QLD Australia
QLD Australia
thanks
Darren Beale
Re: Magnum Force or PST? [Re: Keith Black®] #800542
09/22/10 10:15 AM
09/22/10 10:15 AM
Northern Territory, Australia
Z
Zapp Offline
Zapp  Offline
Z
I was thinking about some when PST advertised them but not sure on quality anyone have experience here?
Re: Magnum Force or PST? [Re: Zapp] #800543
09/22/10 10:50 AM
09/22/10 10:50 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
They are a cast piece. Machining looks good, but some of the dimensions are off. You must shim (aftermarket) caliper brackets that mount to the outside face of the knuckle.
In addition, the tire contacts the tie rod if you run much wheel backspacing.
Re: Magnum Force or PST? [Re: DoctorDiff] #800544
09/22/10 11:48 AM
09/22/10 11:48 AM
Irving, TX
feets Online tonguue
Senior Management
feets  Online Tonguue
Senior Management
Irving, TX
Are they the same dropped spindles that Fat Man sold for the FMJ bodies?
- Stu Harmon
Re: Magnum Force or PST? [Re: feets] #800545
09/22/10 01:36 PM
09/22/10 01:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
No, absolutely not.
Those are are welded up from thick flat stock with a spindle pressed and welded into the center. Some of the outside dimensions of those can be a little goofy too, but really the issue is they do not seem very stout.
I can't think of any reason anyone should be buying a Fat Man spindles for similar price with the cast iron ones out now.
Re: Magnum Force or PST? [Re: feets] #800546
09/22/10 01:37 PM
09/22/10 01:37 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
No. Fatman knuckles are fabricated parts welded together.
Re: Magnum Force or PST? [Re: DoctorDiff] #800547
09/22/10 08:28 PM
09/22/10 08:28 PM
IN
ahy Offline
ahy  Offline
IN
If I'm not mistaken, the originals are forged. A cast version will have meaningfully less strength... sounds like the fabbed versions have less as well.
Re: Magnum Force or PST? [Re: DoctorDiff] #800548
09/22/10 08:56 PM
09/22/10 08:56 PM
AndyF Offline
AndyF  Offline
Yep, you get into the tie rod really quick if you try to run a wide wheel on the MF dropped knuckles.
Re: Magnum Force or PST? [Re: AndyF] #800549
09/23/10 12:12 AM
09/23/10 12:12 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's some pics of the Fatman dropped spindles.
The rubbing seen on the bottom of the Fatman spindle did not rub with the stock spindles...
Re: Magnum Force or PST? [Re: autoxcuda] #800550
09/23/10 03:33 AM
09/23/10 03:33 AM
QLD Australia
QLD Australia
I have the fatman spindles and am throwing them out.
My engineer reckons they are unsafe (multiple pieces and welded etc), hence checking for one-piece replacements.
I thought MF where forged ...? Hmmmm
Darren Beale
Re: Magnum Force or PST? [Re: Keith Black®] #800551
09/25/10 04:34 AM
09/25/10 04:34 AM
Z
Zapp Offline
Zapp  Offline
Z
By the feedback above I think Ill forget that idea
