What insert do you guys recommend for a collector? #798868
09/11/10 07:10 PM
09/11/10 07:10 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
Just got the car running and it is loud what insert do you guys recommend? The car chemistry ones or dyna tech cone ones? Thanks Jason
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: What insert do you guys recommend for a collector? [Re: haddixj] #798869
09/11/10 07:17 PM
09/11/10 07:17 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Neither, just attach mufflers to the collectors. I've never heard anything good about those inserts.
Re: What insert do you guys recommend for a collector? [Re: ProSport] #798870
09/11/10 07:24 PM
09/11/10 07:24 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
if you have a 3" collector, try putting a 2" outside dia. pipe in the collector after you install the choker, uh, i mean the insert. i can't stand those things!!!!!
Re: What insert do you guys recommend for a collector? [Re: haddixj] #798871
09/11/10 07:28 PM
09/11/10 07:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No comment on those things
Re: What insert do you guys recommend for a collector? [Re: tjmarcus1] #798872
09/11/10 07:28 PM
09/11/10 07:28 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
The collector exits out the fender so mufflers are out of the question the car sits a few inchs off the ground so inserts are the only option oh and there 4 inch
Re: What insert do you guys recommend for a collector? [Re: haddixj] #798873
09/11/10 08:08 PM
09/11/10 08:08 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
A stainless steel hootie valve works good! Race cars are supposed to have open headers! Old School all the way!
Re: What insert do you guys recommend for a collector? [Re: DoubleD] #798874
09/11/10 10:00 PM
09/11/10 10:00 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
What is a hootie valve
Re: What insert do you guys recommend for a collector? [Re: haddixj] #798875
09/11/10 11:18 PM
09/11/10 11:18 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
when i said 3", that was just for reference. if you have a 4" collector, you obviously want a 4" collector. with the insert, you will have about 3"
Re: What insert do you guys recommend for a collector? [Re: tjmarcus1] #798876
09/12/10 12:07 AM
09/12/10 12:07 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Will these inserts work to quiet the car for street driving? I was really hoping to use them for that! I planned my street exhaust hookup around using them.
What is the main issue?
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: What insert do you guys recommend for a collector? [Re: Hemi Allstate] #798877
09/12/10 12:16 AM
09/12/10 12:16 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
dynatech makes a set that I have seen used. They didnt make my buddies car quite enough so he wrapped them with some muffler packing and the got a lot better
Re: What insert do you guys recommend for a collector? [Re: joshking440] #798878
09/12/10 12:26 AM
09/12/10 12:26 AM
Mt. Eden Ky.
Mt. Eden Ky.
Well I guess I can experiment. I thought they were like the baffles used in boat headers, and would get me by.
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: What insert do you guys recommend for a collector? [Re: Hemi Allstate] #798879
09/12/10 12:28 AM
09/12/10 12:28 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Re: What insert do you guys recommend for a collector? [Re: Hemi Allstate] #798880
09/12/10 12:38 AM
09/12/10 12:38 AM
Mt. Eden Ky.
Mt. Eden Ky.
Are those preferred over the Car Chemistry?
Unfortunately that is what I have now.
Thanks for the link,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: What insert do you guys recommend for a collector? [Re: Hemi Allstate] #798881
09/12/10 12:42 AM
09/12/10 12:42 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Not familiar with the car chemistry inserts....if the header exits the fender, do you have the length to do the car chemistry style?
Re: What insert do you guys recommend for a collector? [Re: joshking440] #798882
09/12/10 01:17 AM
09/12/10 01:17 AM
Mt. Eden Ky.
Mt. Eden Ky.
My exhaust is side exit rear, in front of the wheel openings. It's close to the floor, and merges to ovalized for ground clearance.
The Car Chemistry inserts slide into the header collectors.
I really don't have room for mufflers.
http://www.carchemistry.com/shop/index.php?l=product_detail&p=20
1996 Ram 1500 Sport
1968 road runner
Re: What insert do you guys recommend for a collector? [Re: Hemi Allstate] #798883
09/12/10 10:08 AM
09/12/10 10:08 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Yes, it will take at least 2 hours for permanent hearing loss, instead of 10 minutes.
What they don't do:
"have no effect on power"
"effectively quiet open exhaust"
What they do best:
transfer money from your bank to theirs
Boffin Emeritus
Re: What insert do you guys recommend for a collector? [Re: polyspheric] #798884
09/12/10 12:38 PM
09/12/10 12:38 PM
Mt. Eden Ky.
Mt. Eden Ky.
What they don't do:
What they do best:
Since they have already done what they do best,and I am not looking to gain power. Hopefully, I can modify the baffles to lower the dbs to an acceptable level.
If not, I will have to be content to set off car alarms, and be equally as irritating as the big sub woofer gang. Maybe get a nod and smile from the loud pipes save lives crowd!!
Does anyone have experience with mods to these? Successful or otherwise would be of some help.
I have my exhaust system finished and ceramic coated, so I am committed to using these for some time.
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
