Page 1 of 3 1 2 3
Guess the Dyno HP! 416" R1A-W5-W8 motor... #797835
09/10/10 12:19 PM
09/10/10 12:19 PM
Phoenix, Arizona
HerboldRacing Offline OP
Phoenix, Arizona
Ryan Johnson is nearing completion of my new W5 head motor. When he is done he is going to dyno and tune it for best performance. What do you guys think the HP numbers will be???
The specs so far...
48 degree R1A 340 block with bushed lifter bores and partially filled
Fully ported W5 heads (flows 339 @ .700) angle milled to 16 deg
498 W7/W8 intake fully ported
950 CFM Proform carburetor
K1 Technologies 4" 4340 crank with 2.10" GM journals
Crower 6.125" middle weight billet I beam rods
Diamond flat top pistons
Custom bullet 48 degree camshaft (109 LSA, 264/268 @ .050")
Crane ultra pro .903" 48 degree .210" offset solid roller lifters
Custom manton pushrods
T&D offset rockers 1.8/1.7 ratio (.693"/.693" lift)
Comp 955-16 pacaloy roller valve springs
Manley stainless race valves
External oil filter and cooler
110 Sunoco race gas
Estimate about 13.5 to 1 static compression ratio.
And a picture of the motor at this point:
So... let the guessing begin!!!
Marvin Herbold 1973 Plymouth Duster 340 Drag Car Blog - http://www.HerboldRacing.com Videos - http://www.YouTube.com/mherbold Pictures - http://gallery.herbold-family.com/main.php?g2_itemId=10331
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: HerboldRacing] #797836
09/10/10 12:36 PM
09/10/10 12:36 PM
ohio
all spooled up Offline
ohio
725 hp
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: HerboldRacing] #797837
09/10/10 12:38 PM
09/10/10 12:38 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Say 712hp 565tq...
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: HerboldRacing] #797838
09/10/10 12:38 PM
09/10/10 12:38 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
580ft lbs @ 5200 / 685hp @ 6900
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: HerboldRacing] #797839
09/10/10 12:41 PM
09/10/10 12:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
588 foot pounds torque and 738 hp.
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: Dodgem] #797840
09/10/10 12:48 PM
09/10/10 12:48 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
sounds extremely similar to my old w5 motor, except different intake and your cam is about 9-10 degrees smaller. dyno's are different but i would suspect somewhere in the area of 660 ish ponies.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: HerboldRacing] #797841
09/10/10 12:48 PM
09/10/10 12:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
700 HP / 550 torque... but then "I don't know nuthin' 'bout no small blocks!"
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: BradH] #797842
09/10/10 03:49 PM
09/10/10 03:49 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
680/580
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: 72demon416] #797843
09/10/10 05:24 PM
09/10/10 05:24 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Am I allowed to guess?
675-680 HP
590-595 TQ
Cam has very slow ramps due to excessively high rocker ratio (for bracket motor) Ended up getting a deal on these rockers from a customer who wanted to use them on a high milage street W2 motor for a good price....
Off shelf pistons, 1/16" 3/16" rings.....
It's nothing really special, just has good set of heads on it.
Actual Compression is 13.1:1 BTW.
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: RyanJ] #797844
09/10/10 05:31 PM
09/10/10 05:31 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
hey.... whats up with just the hp & TQ with no rpm, you guys need to up the stakes here
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: emarine01] #797845
09/10/10 05:34 PM
09/10/10 05:34 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
I bet it makes way more power than what it'll take to run your mid to high 10 second goal.......
If you can't handle the truth, you're living a lie.......
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: emarine01] #797846
09/10/10 05:36 PM
09/10/10 05:36 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
You're in ballpark.... if anything peak TQ might be @ hair higher RPM, but with only 264 @ .050 probably pretty close there in the 5200-5300 range, will be very flat there in that area, so don't think it really matters. If converter is anywhere in 4800-5500 range will run about same down the track, this is'nt a class eliminator car.
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: RyanJ] #797847
09/10/10 05:47 PM
09/10/10 05:47 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Ryan, Ya got a pic of the valley plate to go with the 498? How did it fit up with the 2 degrees cut on the heads?
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: RyanJ] #797848
09/10/10 05:47 PM
09/10/10 05:47 PM
Phoenix, Arizona
Phoenix, Arizona
Sure!!!
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: Big Squeeze] #797849
09/10/10 05:52 PM
09/10/10 05:52 PM
Phoenix, Arizona
Phoenix, Arizona
That is fer sure!
I have a feeling a lot of jaws will drop when I bring the Duster back to my home track with the new motor in it.
I'm going to need to bring several changes of shorts...
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: RyanJ] #797850
09/10/10 05:55 PM
09/10/10 05:55 PM
BradH Offline
BradH  Offline
675-680 HP
590-595 TQ
Like I said, I'm a small-block dummy and took a (s?)w.a.g. myself. I can understand your HP estimate, but that seems like a lot of torque for only 416 cubes.
So, how soon is this going on the pump?
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: BradH] #797851
09/10/10 08:24 PM
09/10/10 08:24 PM
, PA
sleepyhead416 Offline
, PA
675hp
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: BradH] #797852
09/10/10 08:24 PM
09/10/10 08:24 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
675-680 HP
590-595 TQ
I made 1.43 TQ/INCH before with pump gas 11:1 440 SB with good 59* INDY head.... I think we'll be in ballpark of that with this W5 motor. May be hair high guess. 1.38-1.40/Inch may be more realistic, we'll see.
Probably Beginning of week of the 13th @ this point. I've got decent amount of fab work to finish up on this top end including making a valley tray for it (will just be mild steel sheetmetal like a Big block), weld in some AN fittings for external water lines... The shortblock is done, pushrod clearancing is done (this is 48* block) Finished machining heads for T&D rocker geometry...
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: HerboldRacing] #797853
09/10/10 08:43 PM
09/10/10 08:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
More than me...........
Re: Guess the Dyno HP! 416" R1A-W5-W8 motor... [Re: Thumperdart] #797854
09/10/10 11:35 PM
09/10/10 11:35 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
695 lbs @5000 rpm
645 hp @ 5700 rpm
Page 1 of 3 1 2 3
