This totally stink's,,lot's of work ahead of me. #793471
09/05/10 04:18 PM
09/05/10 04:18 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
As i said in a earlier post that I had taken the new converter out and sent it back to Jason at Quickdraw to have it re stalled a little higher, so I put the lod TCI in to make a few run's just for a comparison but right off the bat the front seal started to leak, so I pulled it back out to replace the seal and decided to just give up on my plan and decided to just wait for the converter to come back,,so while it was out and laying under the car on the jack I attempted to put the new seal in but was having trouble getting it started so I just pulled the tranny out from under the car and thats when I found it,,,,a crack half way around the case where the bellhousing mold's into the main gear case you have got to be kidding me,, now I have to build another tranny between now and Norwalk and hope I do it right so their aren't any issues,,just what I wanted to do.
here's the first pic.
Re: This totally stink's,,lot's of work ahead of me. [Re: dartman366] #793472
09/05/10 04:19 PM
09/05/10 04:19 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
next pic. has this happened to anyone else?
Re: This totally stink's,,lot's of work ahead of me. [Re: dartman366] #793473
09/05/10 04:31 PM
09/05/10 04:31 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
too bad you could not have it machined for an ultra bell.darn good thing you found it!
Re: This totally stink's,,lot's of work ahead of me. [Re: dartman366] #793474
09/05/10 04:32 PM
09/05/10 04:32 PM
Indianapolis Indiana
Jamie340 Offline
Jamie340  Offline
Be thankful, that you found it before a catastrophe. That failing on the track could have been life threatening.
However I do understand the frustration.
Jamie
Re: This totally stink's,,lot's of work ahead of me. [Re: blownzoom440] #793475
09/05/10 04:46 PM
09/05/10 04:46 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Bill like stated above check pricing for an ultrabell from summit. If its cracked in front of the pump you are good to go and saved a lot of work. Cutting the stock bell off was the hardest part of the job. all you would need is a little grinding and some longer grade 8 pump bolts.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: This totally stink's,,lot's of work ahead of me. [Re: pittsburghracer] #793476
09/05/10 04:58 PM
09/05/10 04:58 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Bill I have never seen that on a trans before. So do you have another case sitting there that you can transfer in the insides of that one to and get it going? Is there anything you need that maybe I can help you with? Just let me know and I hope you do get it ready for Norwalk!!
Russ
Re: This totally stink's,,lot's of work ahead of me. [Re: pittsburghracer] #793477
09/05/10 05:03 PM
09/05/10 05:03 PM
PA.
"Little"John
"Little"John
PA.
Wow they cost more than I remember.
Campbell Enterprises
727 j.w.92458 395 dollars on sale
904 j.w.92460 " " " "
Summit 336.00 est shipping date 9-24-2010
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: This totally stink's,,lot's of work ahead of me. [Re: dartman366] #793478
09/05/10 05:09 PM
09/05/10 05:09 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Sorry to here that Bill
But im glad you caught it in the garge rather than at the track
Re: This totally stink's,,lot's of work ahead of me. [Re: dartman366] #793479
09/05/10 05:23 PM
09/05/10 05:23 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
sorry to read and see that but like others have said better to find that kind of trouble before it ends up real bad..
Re: This totally stink's,,lot's of work ahead of me. [Re: 1Fast340] #793480
09/05/10 05:41 PM
09/05/10 05:41 PM
K
Kiddart Offline
Kiddart  Offline
K
It happened to me a few years ago in a 904, 3 days befor pinks at milan. thrashed to get a new case put it all back together had trans problems ever since.
I ordered a new trans from Cope once I got the new trans i pulled the old one a part found the main shaft had a slight wow in it. dont know how or why bit check that out as well.
Thank you
Kiddart
Re: This totally stink's,,lot's of work ahead of me. [Re: Kiddart] #793481
09/05/10 06:39 PM
09/05/10 06:39 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well I sent you a PM before I seen this post..call if you need some help..
Re: This totally stink's,,lot's of work ahead of me. [Re: Jamie340] #793482
09/05/10 07:10 PM
09/05/10 07:10 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Jamie
Your telling me,,it was just a stroke of luck that I found it, yes I have another case and will start tomorrow getting it prepped to transferr my good part's over to it,,, the funny thing is it appears that it has been cracked this way for some time and what ever kept it from dumping it's guts is beyond me.
Re: This totally stink's,,lot's of work ahead of me. [Re: dartman366] #793483
09/05/10 07:32 PM
09/05/10 07:32 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
Quote
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: This totally stink's,,lot's of work ahead of me. [Re: dartman366] #793484
09/05/10 07:36 PM
09/05/10 07:36 PM
NC
440Jim Offline
440Jim  Offline
NC
Wow. I never saw that before, and hope I don't see it again. I guess 40 year old parts have lots of time to grow cracks. More of a pain and labor than cost, since you are doing it yourself and have another case. I am thinking the going rate for a 727 core case might be $100-$150, basically what you can get a complete core transmission for.
Looking at the cost of the JW Ultrabell, it doesn't seem to make sense when putting a 727 on a Mopar big or small block. But it would eliminate the need for the flexplate shield, but not the trans shield.
Re: This totally stink's,,lot's of work ahead of me. [Re: Butch] #793485
09/05/10 07:37 PM
09/05/10 07:37 PM
Mountain City, TN
JesseR Offline
JesseR  Offline
Mountain City, TN
We've had that problem before in the truck, went to an ultrabell and no problems since.
82' dodge pickup with a 499 low deck
Re: This totally stink's,,lot's of work ahead of me. [Re: JesseR] #793486
09/05/10 07:45 PM
09/05/10 07:45 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Let me know if I can be of any help.
Re: This totally stink's,,lot's of work ahead of me. [Re: WILD BILL] #793487
09/05/10 08:43 PM
09/05/10 08:43 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
that's funny right there.
sorry Bill just couldn't help myself.
Re: This totally stink's,,lot's of work ahead of me. [Re: dartman366] #793488
09/05/10 09:00 PM
09/05/10 09:00 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I am trying not to laugh realy...........poor bill
Re: This totally stink's,,lot's of work ahead of me. [Re: VernMotor] #793489
09/05/10 09:23 PM
09/05/10 09:23 PM
Akron Ohio
DartMan380 Offline
DartMan380  Offline
Akron Ohio
Had the same thing happen here..
Had a bad vibration in the car that no one could find. The trans was out and getting ready to go back in and I was using a screw driver to scrape some junk off of it and found it. We had this vibration for 2+ months before that..
Re: This totally stink's,,lot's of work ahead of me. [Re: DartMan380] #793490
09/05/10 09:27 PM
09/05/10 09:27 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
funny you should say that, I had a vibration that mysteriously went away early in the season at CC Events @ National trails, but I was also fighting rocker issues then too.
