This totally stink's,,lot's of work ahead of me.
#793471
09/05/10 04:18 PM
09/05/10 04:18 PM
dartman366
Mt. Vernon, Ohio
As i said in a earlier post that I had taken the new converter out and sent it back to Jason at Quickdraw to have it re stalled a little higher, so I put the lod TCI in to make a few run's just for a comparison but right off the bat the front seal started to leak, so I pulled it back out to replace the seal and decided to just give up on my plan and decided to just wait for the converter to come back,,so while it was out and laying under the car on the jack I attempted to put the new seal in but was having trouble getting it started so I just pulled the tranny out from under the car and thats when I found it,,,,a crack half way around the case where the bellhousing mold's into the main gear case you have got to be kidding me,, now I have to build another tranny between now and Norwalk and hope I do it right so their aren't any issues,,just what I wanted to do. here's the first pic.
Re: This totally stink's,,lot's of work ahead of me.
[Re: pittsburghracer]
#793477
09/05/10 05:03 PM
09/05/10 05:03 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Wow they cost more than I remember. Campbell Enterprises 727 j.w.92458 395 dollars on sale 904 j.w.92460 " " " " Summit 336.00 est shipping date 9-24-2010
[Re: 1Fast340]
#793480
09/05/10 05:41 PM
09/05/10 05:41 PM
Posts: 1,552 Michigan
Kiddart
It happened to me a few years ago in a 904, 3 days befor pinks at milan. thrashed to get a new case put it all back together had trans problems ever since.
I ordered a new trans from Cope once I got the new trans i pulled the old one a part found the main shaft had a slight wow in it. dont know how or why bit check that out as well.
Thank you Kiddart
[Re: Jamie340]
#793482
09/05/10 07:10 PM
09/05/10 07:10 PM
dartman366
Mt. Vernon, Ohio
Be thankful, that you found it before a catastrophe. That failing on the track could have been life threatening. However I do understand the frustration. Jamie
Your telling me,,it was just a stroke of luck that I found it, yes I have another case and will start tomorrow getting it prepped to transferr my good part's over to it,,, the funny thing is it appears that it has been cracked this way for some time and what ever kept it from dumping it's guts is beyond me.
[Re: Butch]
#793485
09/05/10 07:37 PM
09/05/10 07:37 PM
Posts: 428 Mountain City, TN
JesseR
Mountain City, TN
We've had that problem before in the truck, went to an ultrabell and no problems since.
82' dodge pickup with a 499 low deck
[Re: JesseR]
#793486
09/05/10 07:45 PM
09/05/10 07:45 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Let me know if I can be of any help.
[Re: dartman366]
#793488
09/05/10 09:00 PM
09/05/10 09:00 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
that's funny right there.
sorry Bill just couldn't help myself.
I am trying not to laugh realy...........poor bill
[Re: DartMan380]
#793490
09/05/10 09:27 PM
09/05/10 09:27 PM
dartman366
Mt. Vernon, Ohio
Had the same thing happen here..
Had a bad vibration in the car that no one could find. The trans was out and getting ready to go back in and I was using a screw driver to scrape some junk off of it and found it. We had this vibration for 2+ months before that..
funny you should say that, I had a vibration that mysteriously went away early in the season at CC Events @ National trails, but I was also fighting rocker issues then too.
