Chrome ignition box or orange? #790449
09/01/10 11:09 PM
09/01/10 11:09 PM
NC
Sixt8Chrgr Offline OP
NC
I have a mildly modified 440 in my 68 Charger will I be ok with the Chrome box for my new electronic ignition or should I stick with the orange box?
Re: Chrome ignition box or orange? [Re: Sixt8Chrgr] #790450
09/01/10 11:22 PM
09/01/10 11:22 PM
IN
ahy Offline
ahy  Offline
IN
Either one should work fine for your application. Just avoid the gold on the street.
Re: Chrome ignition box or orange? [Re: Sixt8Chrgr] #790451
09/01/10 11:33 PM
09/01/10 11:33 PM
(1) yes (2) Dont buy an orange box (the new ones have a significant # of reported probs).
Re: Chrome ignition box or orange? [Re: RapidRobert] #790452
09/02/10 01:56 AM
09/02/10 01:56 AM
Florida, USA.
john e Offline
john e  Offline
Florida, USA.
I'm fixin to install electronic on my '69 Coronet. So what are my options instead of the orange box? Where to find a good one? How will the Chrome hold up for everyday use? The last conversion I did was about 10 years ago, no problems with the orange units then.
Street racing is a mystery to most people, but I've got it figured out. If it blows up with a single 4, go dual quads. If that goes, inject it. And fix it fast.
Re: Chrome ignition box or orange? [Re: john e] #790453
09/02/10 02:17 AM
09/02/10 02:17 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If you didn't know, make sure you install an electronic voltage regulator when you install the electronic ignition.
It's required, 69's have point style voltage regulator.
Re: Chrome ignition box or orange? [Re: SNK-EYZ] #790454
09/02/10 04:25 AM
09/02/10 04:25 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I ran a chrome on the street for quite a while. No problems.
Re: Chrome ignition box or orange? [Re: john e] #790455
09/02/10 07:18 AM
09/02/10 07:18 AM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
You can also try the box from FBO.
Re: Chrome ignition box or orange? [Re: fbernard] #790456
09/02/10 08:00 AM
09/02/10 08:00 AM
florida
P
PJM Offline
PJM  Offline
P
florida
Switched from orange to chrome box. Couldn't be happier!
Re: Chrome ignition box or orange? [Re: john e] #790457
09/02/10 09:05 AM
09/02/10 09:05 AM
NY usa
540challenger Offline
NY usa
Before my car went into the body shop i put 6000+ miles on my car a year for 3 years with no problems.
My girlfriends Dart right now has an ornage box for 2 years now with no problems however she only put on maybe 100 miles on it
Re: Chrome ignition box or orange? [Re: Sixt8Chrgr] #790458
09/02/10 09:50 AM
09/02/10 09:50 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I ran orange boxes galore until 10-15 years ago. All of the sudden I had failure after failure.
I run chrome boxes on everything now- my motorhome has a chrome box. Trouble free.
My only deviation is my Jensen Interceptor. I went with an FBO setup, it works awesome.
CrAzYMoPaRGuY
Re: Chrome ignition box or orange? [Re: Sixt8Chrgr] #790459
09/02/10 10:11 AM
09/02/10 10:11 AM
TN
'84 D150 Shorty Offline
Pickup Man
Pickup Man
TN
You could install an HEI on it there are several threads here about it....
Re: Chrome ignition box or orange? [Re: '84 D150 Shorty] #790460
09/02/10 03:05 PM
09/02/10 03:05 PM
Re: Chrome ignition box or orange? [Re: RapidRobert] #790461
09/02/10 04:17 PM
09/02/10 04:17 PM
P
Paul_Fancsali Offline
P
Want a mopar box get one for the Dodge ram with 360 -1980s version reliable and not limited rev wise. Myself I would use a pertronix reliable and easy to install and have never given me a problemI have used all the mopar wonder boxees and own all except the gold. The stock box works every bit as good and I saw no et advantage period
Re: Chrome ignition box or orange? [Re: Paul_Fancsali] #790462
09/02/10 05:32 PM
09/02/10 05:32 PM
TN
Pickup Man
Pickup Man
TN
I still vote HEI *I'm biased cuz I got HEI* it smoothed out the idle, makes for crisper acceleration, and I noticed the other day, that when I downshift and let off the gas it isn't poppin out the exhaust anymore, which tells me that its burnin the fuel better
Re: Chrome ignition box or orange? [Re: '84 D150 Shorty] #790463
09/02/10 09:15 PM
09/02/10 09:15 PM
I wanna try an E coil w & wo the HEI module to see which is making the most difference. What is the white "thermal paste"? It's gotta be better than the dielectric grease I was using and the small capsule that come w those modules has the white paste. I didn't have any probs but I'm paranoid about (ign) breakdowns and anything I can do ahead of time to better my odds...
Re: Chrome ignition box or orange? [Re: RapidRobert] #790464
09/02/10 09:38 PM
09/02/10 09:38 PM
TN
Pickup Man
Pickup Man
TN
Not sure what the white paste is made of, all I know is it helps to transfer the heat the heat sinc, so your module won't fry. As to which component is helping the most, I think its 50/50. The module is has better capabilities, especially in higher RPM's, and the coil fires hotter, so together...KABLAM
Re: Chrome ignition box or orange? [Re: '84 D150 Shorty] #790465
09/02/10 09:46 PM
09/02/10 09:46 PM
What's the brand/part # of the paste so I can grab some. Reportedly GM back in the early 70's hired some retired NASA space scientists who subsequently developed the HEI module . I've ran it & it does kick out one heck of a spark & Jacobs ign also reports that it it the only module that increases dwell as rpm increases.
Re: Chrome ignition box or orange? [Re: RapidRobert] #790466
09/03/10 07:38 PM
09/03/10 07:38 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have had this orange box on my 63 since 1998. Still works great on my 63. I shift it about 6200 and it never misses a beat. Ron
Re: Chrome ignition box or orange? [Re: RapidRobert] #790467
09/03/10 08:53 PM
09/03/10 08:53 PM
Canada
Canada
I'm glad they retired, as most GM guys can tell you those HEI modules were very prone to failure.
My buddy's Dad had GM cabs in the early 80s and used to toss spare modules in the glovebox of every cab.
CrAzYMoPaRGuY
Re: Chrome ignition box or orange? [Re: CrAzYMoPaRGuY] #790468
09/04/10 12:10 AM
09/04/10 12:10 AM
Now that you mention it I remember that.
