ok bail me out wiring starter relay #789702
09/01/10 12:18 AM
09/01/10 12:18 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
since I am using a neutral safety switch I need to use a relay. It was 98 degrees here today maybe hotter in the shop . I think I cooked my brain.I am brain dead tonight and can't remember how to wire it using a button. I know one prong is the connection for the safty the other used to do neutral light ? switch,the screw goes to the solenoid ? what goes where and where does what go
home of the
Sox and Martin Hemi Duster
Re: ok bail me out wiring starter relay [Re: HEMIFRED] #789703
09/01/10 12:25 AM
09/01/10 12:25 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
THe large terminal on the right goes to the battery, the one in the middle goes to the starter..
The slip on connectors energize the relay... one goes to the keyswitch, the other goes to the NSS and is looking for chassis ground.. which is only present when in nuetral or park..
Re: ok bail me out wiring starter relay [Re: Jeepmon] #789704
09/01/10 12:29 AM
09/01/10 12:29 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
use the letters please
home of the
Re: ok bail me out wiring starter relay [Re: HEMIFRED] #789705
09/01/10 12:29 AM
09/01/10 12:29 AM
WA
JD Dart Offline
JD Dart  Offline
WA
The neutral safety switch makes the grd connect that one to the push on lug the other push on lug to the start switch the middle one with the screw in it to the starter sol and the stud to battery.
Re: ok bail me out wiring starter relay [Re: HEMIFRED] #789706
09/01/10 12:30 AM
09/01/10 12:30 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
D Battery
C Solenoid on Starter
B NSS
A Ignition Key Switch
Re: ok bail me out wiring starter relay [Re: Jeepmon] #789707
09/01/10 12:35 AM
09/01/10 12:35 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Now put down the Grey Goose and finish already
Re: ok bail me out wiring starter relay [Re: Jeepmon] #789708
09/01/10 12:35 AM
09/01/10 12:35 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
ok thanks exactly how I had it hours ago and gave up trying. it's bad relay out of the box .
I was making my self crazy testing and checking all the wires and connections. that was a waste as I just rewired that car,
man I hate when that happens
thanks
home of the
Re: ok bail me out wiring starter relay [Re: Al_Alguire] #789709
09/01/10 12:40 AM
09/01/10 12:40 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
it's been a year since the last one and that sucker had me going to the freezer for my bottle.
I have a used one around and it's going on right now. I want to be in Indy Friday night. after finals Monday over to Mike Roth's for the Cuda headers. then chassis set up.
home of the
Re: ok bail me out wiring starter relay [Re: Jeepmon] #789710
09/01/10 12:42 AM
09/01/10 12:42 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
D Battery
B NSS
D, is the battery feed
C, sends the volts to trip the starter solinoid.
B. the nss/ground!
A. Positive feed from the IGN. switch.
Re: ok bail me out wiring starter relay [Re: Sport440] #789711
09/01/10 12:56 AM
09/01/10 12:56 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
D Battery
B NSS
B. the nss/ground!
and it's still a bad relay
home of the
Re: ok bail me out wiring starter relay [Re: Jeepmon] #789712
09/01/10 01:34 AM
09/01/10 01:34 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
D Battery
B NSS
(A) Feed from Ignition switch - lost in bulkhead fire.
(B) Ground from Neutral switch - urban myth; never installed successfully.
(C)Starter Solenoid Feed - energizes starter when jumped to "D"
(D) Battery Feed - where "C" is jumped to with rusty screwdriver, spare keys, or pliers.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: ok bail me out wiring starter relay [Re: Evil Spirit] #789713
09/01/10 01:41 AM
09/01/10 01:41 AM
Arizona
Chris'sBarracuda Offline
Arizona
D Battery
B NSS
That's why I use these instead..
Chris..
Re: ok bail me out wiring starter relay [Re: Chris'sBarracuda] #789714
09/01/10 10:25 AM
09/01/10 10:25 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
D Battery
B NSS
Chris..
So do I. Maybe Ford does have a better idea.
Re: ok bail me out wiring starter relay [Re: HEMIFRED] #789715
09/01/10 12:59 PM
09/01/10 12:59 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
D Battery
B NSS
B. the nss/ground!
Hey Fred did you get it working?
I just went through this on my Barracuda.
EASIEST way is to have shifter in N and check to see if you have ground or continuity on the wire from the terminal marked G. IF not the NSS is bad or the wire is opened!
Or put a wire from Gnd term. on relay to ground and see if it starts.(MAKE SURE YOU ARE IN P OR N)
Don
Re: ok bail me out wiring starter relay [Re: cudadon] #789716
09/01/10 01:46 PM
09/01/10 01:46 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
make sure the nss is good I just had to replace the one on my 727 because it did not ground to the small center point of the switch itself,,I realize you I believe are running a PG but the principle is the same.
Re: ok bail me out wiring starter relay [Re: dartman366] #789717
09/01/10 05:21 PM
09/01/10 05:21 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Them Ford relays are for Fords.LOL
As far as I know I am still using the original 1965 Mopar starter relay on my Barracuda. But, it's a street car with stock firewall and wiring harness.
OK YOU GOT ME
I confess the wiring harness has been hacked on quite a bit and is not original but the relay is.
Leon
