Re: Your ET's with RHS iron heads
[Re: Wedgeman]
#785841
08/28/10 10:49 PM
08/28/10 10:49 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
How is your timing? If you used the factory timing marks have you checked the timing marks VS the actual piston position? Sometimes the marks don't line up where the should be.
Is it missing or bogging at all?
[Re: tjmarcus1]
#785843
08/29/10 06:58 PM
08/29/10 06:58 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
SOMETHING IS WAY OFF!!!!!!!!!!!!!!!!! i used the caps to stress a point. it's not the vert or the trans.{ it should be faster than that with a stock vert and a 3.23 gear. small exhaust? cam off a tooth? no timing? too much timing?{which i doubt,it would probably be kicking back against the starter]
Yeah no s#it lol, something is definitly off, my piss ass junkyard 360 magnum with RHS heads run 12.5s @ 105 shifting @ 5100, make sure its getting good fuel supply. I'm also running a spool, its very easy to push on a straight!
[Re: joedust451]
#785844
08/29/10 08:47 PM
08/29/10 08:47 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
I know something is wrong , but what ???
Yes there was a lot of slippage thursday at the track, non glue on the pavement on thursdays, my 60 ft was killing me for sure !!timing is ok, 180 psi on every cylinder, 250/294 mec cam...I have all the rught stuff !! I will sure put my finger on it.........I took the engine out today, just to see........ Dan
[Re: Wedgeman]
#785848
08/30/10 09:55 PM
08/30/10 09:55 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
OK....just to keep you informed
Took the engine out to see..
Looks like one rod bearing shot and the mains are in very bad shape.....too bad I waisted money on an engine builder for assy,.....sould have done it myself as usual. Dan
What the...?? How old was this motor? Hopefully the "builder" will stand behind it.
[Re: Wedgeman]
#785850
08/31/10 12:29 AM
08/31/10 12:29 AM
joedust451
super gas
super gas
Branson, Mo.
Not even 400 miles on the motor.....and I stand alone. Dan
I wouldn't let that machinest touch it again , fix it yourself.
