Re: Your ET's with RHS iron heads [Re: Quicksilver440] #785840
08/28/10 10:08 PM
08/28/10 10:08 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I had someone step on the pedal while I was looking at the venturis
THis is a stroker kit assembled by an engine builder
Dan
Re: Your ET's with RHS iron heads [Re: Wedgeman] #785841
08/28/10 10:49 PM
08/28/10 10:49 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
How is your timing? If you used the factory timing marks have you checked the timing marks VS the actual piston position? Sometimes the marks don't line up where the should be.
Is it missing or bogging at all?
Re: Your ET's with RHS iron heads [Re: HotRodDave] #785842
08/29/10 01:05 AM
08/29/10 01:05 AM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
SOMETHING IS WAY OFF!!!!!!!!!!!!!!!!! i used the caps to stress a point. it's not the vert or the trans.{ it should be faster than that with a stock vert and a 3.23 gear. small exhaust? cam off a tooth? no timing? too much timing?{which i doubt,it would probably be kicking back against the starter]
Re: Your ET's with RHS iron heads [Re: tjmarcus1] #785843
08/29/10 06:58 PM
08/29/10 06:58 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Yeah no s#it lol, something is definitly off, my piss ass junkyard 360 magnum with RHS heads run 12.5s @ 105 shifting @ 5100, make sure its getting good fuel supply. I'm also running a spool, its very easy to push on a straight!
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Your ET's with RHS iron heads [Re: joedust451] #785844
08/29/10 08:47 PM
08/29/10 08:47 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I know something is wrong , but what ???
Yes there was a lot of slippage thursday at the track, non glue on the pavement on thursdays, my 60 ft was killing me for sure !!timing is ok, 180 psi on every cylinder, 250/294 mec cam...I have all the rught stuff !! I will sure put my finger on it.........I took the engine out today, just to see........
Dan
Re: Your ET's with RHS iron heads [Re: Wedgeman] #785845
08/30/10 09:12 AM
08/30/10 09:12 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
What's wrong with the converter ????
RT .533
60 ft 2.23
1/8 8.8 82.8 mph
1/4 13.6 99.3 mph
IT JUST SUCKS !!!!!!!!
what intake/carb?
how heavy is the car?
what do you have for exhaust?
I agree with others, your 60' sucks...cut it down to the 1.50's and you're in the mid 12's, possibly...
but your MPH isn't too high, so it almost seems like it's laying down on the big end?
2017 Grand Cherokee Overland
Re: Your ET's with RHS iron heads [Re: patrick] #785846
08/30/10 01:30 PM
08/30/10 01:30 PM
Kansas wishing I was in Ohio
SeanD Offline
SeanD  Offline
If the car is hard to push in a straight line on a flat level surface look at the brakes hanging up first then make sure rear housing is NOT bent.
If you have a mechanical fuel pump with 5/16 fuel line switch to electric fuel pump and min. 3/8 line.
What type/manufacturer is your convertor? Money spent on a cheap convertor is wasted money.
Good luck.
Re: Your ET's with RHS iron heads [Re: SeanD] #785847
08/30/10 09:28 PM
08/30/10 09:28 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
OK....just to keep you informed
Took the engine out to see..
Looks like one rod bearing shot and the mains
are in very bad shape.....too bad I waisted money on an engine builder for assy,.....sould have done it myself as usual.
Dan
Re: Your ET's with RHS iron heads [Re: Wedgeman] #785848
08/30/10 09:55 PM
08/30/10 09:55 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Dan
What the...?? How old was this motor? Hopefully the "builder" will stand behind it.
Re: Your ET's with RHS iron heads [Re: cudadoug] #785849
08/30/10 11:17 PM
08/30/10 11:17 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Not even 400 miles on the motor.....and I stand alone.
Dan
Re: Your ET's with RHS iron heads [Re: Wedgeman] #785850
08/31/10 12:29 AM
08/31/10 12:29 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Dan
I wouldn't let that machinest touch it again , fix it yourself.
Re: Your ET's with RHS iron heads [Re: joedust451] #785851
08/31/10 06:26 PM
08/31/10 06:26 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
.....And with you guys, I'm bulletproof !!
Can't do worst anyway
Dan
