DCC formula Organisol paint on RR Hood. #781166
08/23/10 02:32 AM
08/23/10 02:32 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
I had my local paint guru mix up the new DCC single stage paint for my Roadrunner hood.
By contrast I had the correct laquer formula mixed for the dash and steering column..
The new formula is a really nice satin finish, and much different than the dash.., which came out very rough after drying, the laquer texture seems a lot rougher than original parts.
Re: DCC formula Organisol paint on RR Hood. [Re: sthemi] #781167
08/23/10 02:33 AM
08/23/10 02:33 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Another view..
Re: DCC formula Organisol paint on RR Hood. [Re: sthemi] #781168
08/23/10 06:41 AM
08/23/10 06:41 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
sthemi,
The 68 black out on a black hood is wicked looking!
Re: DCC formula Organisol paint on RR Hood. [Re: sthemi] #781169
08/23/10 12:52 PM
08/23/10 12:52 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Very very nice looking! I may go that color on my hood stripes...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: DCC formula Organisol paint on RR Hood. [Re: sycboi] #781170
08/24/10 01:30 AM
08/24/10 01:30 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks for the compliments, lots of parts to put back together before I can give it a test drive !
Re: DCC formula Organisol paint on RR Hood. [Re: sthemi] #781171
08/24/10 07:16 AM
08/24/10 07:16 AM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
When you sprayed the laquer , how did you reduce it ? Its supposed to be 1 part paint 3 parts thinner .
Re: DCC formula Organisol paint on RR Hood. [Re: FY1TA] #781172
08/25/10 12:58 AM
08/25/10 12:58 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
I painted it a couple of years ago, but I mixed it 1 to 1 1/2, which was the norm back when Laquer was common..
I still have the headliner conceal moldings to paint,I will mix it a lot thinner and give feedback..
The DCC did come with a 6 to 2 to 1 mix clearly labeled on the can..
The reason I went with the DCC was that I didnt want to chance laquer on top of my fresh DCC paint..
The dash had DP primer so the laquer was no problem..
Re: DCC formula Organisol paint on RR Hood. [Re: sthemi] #781173
08/27/10 12:01 PM
08/27/10 12:01 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I had my local paint guru mix up the new DCC single stage paint .....
Okay, I'll show my ignorance, what is 'DCC'?
Re: DCC formula Organisol paint on RR Hood. [Re: 6PakBee] #781174
08/27/10 01:53 PM
08/27/10 01:53 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
DCC, is PPG "Concept" premium line of single stage (no clear required) paint.
Re: DCC formula Organisol paint on RR Hood. [Re: sthemi] #781175
08/30/10 08:17 AM
08/30/10 08:17 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thanks for the reply. What's the paint code in DCC for the Organisol?
Re: DCC formula Organisol paint on RR Hood. [Re: 6PakBee] #781176
08/30/10 12:19 PM
08/30/10 12:19 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Im not clear on your starting post.
Are you asking why the finish is different than the dash you painted?
The dash should be the rough texture you spoke of. its referred to as a suede finish which is rough and not shiny to reduch sun glare reflected back into the windshield from the dash. I didnt use the suede paint on the R/T and on sunny days the glare is a problem.
If you already knew this than please pardon the interuption.
Re: DCC formula Organisol paint on RR Hood. [Re: 6PakBee] #781177
08/30/10 01:37 PM
08/30/10 01:37 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I think it is DCC9355. sthemi, is that what you used?
65 Barracuda
70 Challenger
Re: DCC formula Organisol paint on RR Hood. [Re: jrwoodjoe] #781178
08/31/10 01:32 AM
08/31/10 01:32 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
The DCC formula for Organisol is DCC 9355
The Satin finish interior paint is Laquer DDL 9324
