DCC formula Organisol paint on RR Hood.
#781166
08/23/10 02:32 AM
08/23/10 02:32 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I had my local paint guru mix up the new DCC single stage paint for my Roadrunner hood. By contrast I had the correct laquer formula mixed for the dash and steering column.. The new formula is a really nice satin finish, and much different than the dash.., which came out very rough after drying, the laquer texture seems a lot rougher than original parts.
Re: DCC formula Organisol paint on RR Hood.
[Re: sthemi]
#781169
08/23/10 12:52 PM
08/23/10 12:52 PM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
Very very nice looking! I may go that color on my hood stripes...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
[Re: FY1TA]
#781172
08/25/10 12:58 AM
08/25/10 12:58 AM
sthemi
Chicago Burbs
I painted it a couple of years ago, but I mixed it 1 to 1 1/2, which was the norm back when Laquer was common.. I still have the headliner conceal moldings to paint,I will mix it a lot thinner and give feedback.. The DCC did come with a 6 to 2 to 1 mix clearly labeled on the can.. The reason I went with the DCC was that I didnt want to chance laquer on top of my fresh DCC paint.. The dash had DP primer so the laquer was no problem..
[Re: sthemi]
#781173
08/27/10 12:01 PM
08/27/10 12:01 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
I had my local paint guru mix up the new DCC single stage paint .....
Okay, I'll show my ignorance, what is 'DCC'?
[Re: 6PakBee]
#781174
08/27/10 01:53 PM
08/27/10 01:53 PM
sthemi
Chicago Burbs
DCC, is PPG "Concept" premium line of single stage (no clear required) paint.
[Re: sthemi]
#781175
08/30/10 08:17 AM
08/30/10 08:17 AM
6PakBee
North Dakota
Thanks for the reply. What's the paint code in DCC for the Organisol?
[Re: 6PakBee]
#781176
08/30/10 12:19 PM
08/30/10 12:19 PM
Posts: 6,583 SE Pa.
LimeliteAero
SE Pa.
Im not clear on your starting post. Are you asking why the finish is different than the dash you painted? The dash should be the rough texture you spoke of. its referred to as a suede finish which is rough and not shiny to reduch sun glare reflected back into the windshield from the dash. I didnt use the suede paint on the R/T and on sunny days the glare is a problem. If you already knew this than please pardon the interuption.
