Re: 440 W5 Dyno Session [Re: BradH] #776985
08/19/10 02:29 PM
08/19/10 02:29 PM
AndyF Offline
AndyF  Offline
Bullet Roller ~272 @ .050, ~.700 lift, 108 LSA
Just supposed to be a pump gas street/strip deal, I think with more emphasis on street.
Anybody besides me look at those two statements above and chuckle a bit?
Yep. The 427 inch small block that I just finished up has a 236 @ 050 roller cam in it.
Re: 440 W5 Dyno Session [Re: AndyF] #776986
08/19/10 02:41 PM
08/19/10 02:41 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
My "street" 408 has comps CRSZRR-10 solid roller, and its 248/254 @50, and They wanted me to stick a bigger one in it. I spoke to Ryan, and Brian both, Brian wanted me to have a custom cam with 274 @50 with over 600 lift. Then we talked and I told him this is a street car 85% of the time. We went with this on instead, so This cam would be GNARLEY I would think.
But I sure would like it.
Kasey
Re: 440 W5 Dyno Session [Re: Moparnut426] #776987
08/19/10 03:19 PM
08/19/10 03:19 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
I'm thinking I might win the award for having the meanest idle @ the ice cream stand though LOL.
It's going to sound awesome!!!!!!
Re: 440 W5 Dyno Session [Re: 72demon416] #776988
08/19/10 03:49 PM
08/19/10 03:49 PM
Finland
mafo Offline
mafo  Offline
Finland
always nice to read your posts,
now can we build a 1000 hp n/a 400 incher ?
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: 440 W5 Dyno Session [Re: RyanJ] #776989
08/19/10 04:28 PM
08/19/10 04:28 PM
north battleford sask
9
93reefblue Offline
93reefblue  Offline
"Just supposed to be a pump gas street/strip deal, I think with more emphasis on street. "
if street means quiet hiway at night(WOT)??!!YUP
Re: 440 W5 Dyno Session [Re: 93reefblue] #776990
08/19/10 08:11 PM
08/19/10 08:11 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Ryan, you did such a good job on my small block Eddy heads, intake and cam that I ordered my Big Block stuff from you instead of the mainstream. I appreciate your candidness and you saved me money by your advice compared to others. I'm really looking forward to my stroker big block's results after you work those heads. But yeah, I agree when it comes to small blocks I think they are just too much fun!
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: 440 W5 Dyno Session [Re: AndyF] #776991
08/19/10 08:20 PM
08/19/10 08:20 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Typical Freudian undercompensation.
Re: 440 W5 Dyno Session [Re: tubtar] #776992
08/19/10 11:47 PM
08/19/10 11:47 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
AndyF, what kind of cylinder pressure does that 427 have with such a small cam?
Rick, that 440 will definately make some rumble under the hood of your demon. Should easily go low 10's at the track, and even in the 9's if you can get it to hook!
What did the current 416 you have in the car do performance wise? ( ET and mph and weight) -Andy
Re: 440 W5 Dyno Session [Re: tubtar] #776993
08/19/10 11:53 PM
08/19/10 11:53 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Good reading material Thankx
Re: 440 W5 Dyno Session [Re: 340_Dart] #776994
08/20/10 12:25 AM
08/20/10 12:25 AM
AndyF Offline
AndyF  Offline
I think it was 180 psi. It is a pump gas street motor. A 236 at 50 roller isn't really a small cam for 427 inches. Lots of crate motors use cams that are smaller than that. Chevy puts a 211 at 050 cam in the 502 crate motor for example.
The car that the 427 is in goes 150+ mph so it is making plenty of power. Idles at 800 rpm which is nice.
Re: 440 W5 Dyno Session [Re: 340_Dart] #776995
08/20/10 12:57 AM
08/20/10 12:57 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Andy, there is lots of unknowns with my car. I've never weighed it but it's got to be 3400/3500 lbs- I haven't taken ANY weight out so it's got that against it. I never made it to the track before I grenaded it but the night I hurt the motor I was making some passes out on the highway with a freinds passport. Now I know a lot of people don't put a lot of stock in the results of those things but this one was consistantly showing 3 mph slow and ET was within a 10'th of having been tried in a car that does run at the track- so with that in mind my car cars best was 12.1 @ 119.3( & it seems like it's always poor air here for performance). I was having a hell of a time to get it out of the hole without bogging or blowing the tires away- it was like a on/off switch. The track will certainly show something more realistic of it's potential-I would think mid to high tens given it's obescity. Someday I'll get there... but in the meantime it should be a lot of fun to tool around town in
I see youv'e caught the speed bug again with your Dart
Re: 440 W5 Dyno Session [Re: RyanJ] #776996
08/20/10 11:02 AM
08/20/10 11:02 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good reading, thanks Ryan.
The M1 intakes mostly seem to be designed for a 340.
Rich H.
Esse Quam Videri
Re: 440 W5 Dyno Session [Re: 72demon416] #776997
08/20/10 12:19 PM
08/20/10 12:19 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
It does sounds good.... even though it is low compression, it definitely does not sound like a 340... you know it's a bit more than that when you hear it.
Can't wait to see how those Goodyear Radials hook up LOL.
Re: 440 W5 Dyno Session [Re: RyanJ] #776998
08/20/10 01:24 PM
08/20/10 01:24 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
hey ryan ,just a bit of topic ,with your turbo motor made good power aspirated mild comp good heads small cam ,have you done many big heads small cam engines with as good results .thanks
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: 440 W5 Dyno Session [Re: Ian] #776999
08/20/10 06:15 PM
08/20/10 06:15 PM
9
93reefblue Offline
93reefblue  Offline
ryan
unless i missed it ..
what is the expected gains going from the m1 to indy intake.
thanks,
andy h
Re: 440 W5 Dyno Session [Re: 93reefblue] #777000
08/20/10 09:49 PM
08/20/10 09:49 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
I'm sure it would put at least 30-40 FT lbs in it.
I hav'nt done alot of big head motors with real small cams, that 242 I had in my W9 turbo motor was smallest cam I've ever dynoed.
Re: 440 W5 Dyno Session [Re: 72demon416] #777001
08/20/10 09:51 PM
08/20/10 09:51 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
Well, I have to tip my hat to Ryan, I am extremely pleased with his personal service and professionalism- I'm sure as most people on this board already know he is a major asset to all us small block Mopar guys. Shady Dell has been simply excellent to deal with, I don't think it's very often you'll get your engine builder to reply to your (many)emails when he's at home on the couch trying to relax after working on this crap all day. So..thanks Ryan. (does this advertising campaign earn me any discounts LOL)
I am very pleased with the results...it made 40-60 hp more than I was really expecting given it's shortcomings that I imposed. Yes, it is probably the worst intake for power but I had used it because I am not excited about cutting my hood for carb/air cleaner clearance and the M1 is quite a bit lower than the Indy. We'll see- maybe there will be a Indy on there yet someday...
This is supposed to be a "semi" stock appearing pump gas deal so for not running a mechanical water pump, vac pump, having only moderate compression and a poor intake think it is pretty good results.
Awesome report. I think I am the other lucky guy with the small chamber heads but I think mine liked 39 timing.
I hope to get back up there in the spring at least to upgrade mine to your specs.
Ryan, great work as usual!
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
