Fuel pump problem
#771765
08/11/10 09:21 PM
08/11/10 09:21 PM
Posts: 44 Jackson, MI
burch500
Jackson, MI
I took out my engine to replace the rear main and all the gaskets and to repaint it.
Now that it is back in the car I can't get any fuel from the pump. I took off the pump and bench tested it and it shot gas across my bench. I removed the distributor to check the pump rod. It was moving like it should. But still no gas is being pumped.
When I did this I had a gas line running into a bottle full of gas in case it was plugged from the tank.
The engine is a 400.
1966 Coronet
400 ci.
727
Re: Fuel pump problem
[Re: kilroy]
#771767
08/12/10 12:06 AM
08/12/10 12:06 AM
burch500
Jackson, MI
Yes. Push rod was in the right spot. I could see it moving on the cam as the engine was turned over. If it was wrong it wouldn't stay against the cam.
1966 Coronet
400 ci.
727
[Re: burch500]
#771770
08/12/10 04:11 PM
08/12/10 04:11 PM
RapidRobert
get a length of 5/16 fuel line and a funnel and hook it to the pump inlet & dribble some gas in to prime it
