Fuel pump problem #771765
08/11/10 09:21 PM
08/11/10 09:21 PM
Jackson, MI
burch500 Offline OP
burch500  Offline OP
Jackson, MI
I took out my engine to replace the rear main and all the gaskets and to repaint it.
Now that it is back in the car I can't get any fuel from the pump.
I took off the pump and bench tested it and it shot gas across my bench.
I removed the distributor to check the pump rod. It was moving like it should. But still no gas is being pumped.
When I did this I had a gas line running into a bottle full of gas in case it was plugged from the tank.
The engine is a 400.
1966 Coronet 400 ci. 727
Re: Fuel pump problem [Re: burch500] #771766
08/11/10 09:45 PM
08/11/10 09:45 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Sure you got fuel pump push rod under the push rod? It can be forced together this way.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Fuel pump problem [Re: kilroy] #771767
08/12/10 12:06 AM
08/12/10 12:06 AM
Jackson, MI
burch500 Offline OP
burch500  Offline OP
Jackson, MI
Yes. Push rod was in the right spot. I could see it moving on the cam as the engine was turned over. If it was wrong it wouldn't stay against the cam.
Re: Fuel pump problem [Re: burch500] #771768
08/12/10 12:23 AM
08/12/10 12:23 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
measure the push rod length , it may be woren !
Re: Fuel pump problem [Re: calrobb2000] #771769
08/12/10 08:27 AM
08/12/10 08:27 AM
Jackson, MI
burch500 Offline OP
burch500  Offline OP
Jackson, MI
I will check the pushrod, but it ran fine when I pulled the engine out.
Re: Fuel pump problem [Re: burch500] #771770
08/12/10 04:11 PM
08/12/10 04:11 PM
get a length of 5/16 fuel line and a funnel and hook it to the pump inlet & dribble some gas in to prime it
