Harland Sharp Question #770670
08/10/10 02:41 PM
08/10/10 02:41 PM
Finally a HUSKER again
Moparnut426 Offline OP
How can ya tell a 1.5 from a 1.6 rocker? Mine are an older set with nothing laser etched on them, and Previous owner thought they are 1.5s.
I guess I should call Harland Sharp, Mine are on the way too them to get a rebuild job.
Their web site shows the 1.5s pushrod oil hole a little bit farther from the adjuster base than the 1.6 but They never say in the reading.
Kasey
Re: Harland Sharp Question [Re: Moparnut426] #770671
08/10/10 04:26 PM
08/10/10 04:26 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
Re: Harland Sharp Question [Re: kruger] #770672
08/10/10 04:40 PM
08/10/10 04:40 PM
Thats for a big block, Mine is a small block, sorry I should have had that in the origional post.
Kasey
Re: Harland Sharp Question [Re: Moparnut426] #770673
08/10/10 04:50 PM
08/10/10 04:50 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Re: Harland Sharp Question [Re: mopowers] #770674
08/10/10 05:23 PM
08/10/10 05:23 PM
Thats the picture on their site, Its bigger there, and It looks like the only diff is the hole location.
Kasey
Re: Harland Sharp Question [Re: Moparnut426] #770675
08/10/10 06:27 PM
08/10/10 06:27 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
You have to think like a lever.
To get more lift ( higher ratio ) , the driven side needs to be closer to the pivot.
This isn't much help when you don't have a dimension or different piece to compare it to.
But you can tell from the pic that the 1.5 hole is closer to the edge of the arm.
Doesn't matter which block it is for , that's just how geometry works.
Re: Harland Sharp Question [Re: mopowers] #770676
08/11/10 02:46 AM
08/11/10 02:46 AM
http://www.harlandsharp.com/sb_mopar.htm
look at the edge of the adjuster holes in relation to the center of the rocker shatfs, the 1.5 is way closer to the outside edge of the rocker arm than the 1.6 is . To change the ratio they move the adjuster in closer to the rocker shafts
Re: Harland Sharp Question [Re: tubtar] #770677
08/11/10 05:24 AM
08/11/10 05:24 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Re: Harland Sharp Question [Re: Cab_Burge] #770678
08/11/10 09:34 AM
08/11/10 09:34 AM
I see that now. As soon as they get back from Harland Sharps shop, Ill check them over a little bit better.
Kasey
Re: Harland Sharp Question [Re: Moparnut426] #770679
08/11/10 09:47 AM
08/11/10 09:47 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
If you can't tell by looking at them, set them up on an engine and measure them. First, measure the lobe lift on a cam. Say the lobe lift is .300". Then measure the lift at the valve side. If valve lift is .450, then you have a 1.5 ratio (.300 x 1.5). If the valve lift is .480, then you have a 1.6 rocker (.300 x 1.6).
