You have to think like a lever.
To get more lift ( higher ratio ) , the driven side needs to be closer to the pivot.
This isn't much help when you don't have a dimension or different piece to compare it to.
But you can tell from the pic that the 1.5 hole is closer to the edge of the arm.
Doesn't matter which block it is for , that's just how geometry works.
